Swivel/Tilt Wall Mount for 13" to 27" TVs and
Monitors
MODEL NUMBER: DWM1327SE
Highlights
Fits most flat-panel displays
from 13 to 27 in.
One-touch adjustment for
comfortable viewing
180° swivel and -15° to +15° tilt
for wide range of motion
Supports up to 33 lbs (14.9 kgs)
Package Includes
Hangs a flat-panel television, monitor or other display on the wall. Ideal for home, office, hotels, bars and
restaurants. Swivels and tilts to provide optimal viewing angles.
Description
The VESA-compliant DWM1327SE Swivel/Tilt Wall Mount allows you to mount your flat-panel television,
monitor or other display on the wall. Ideal for home, office, hotels, bars and restaurants, it fits most flatpanel displays from 13 to 27 inches.
The full-motion swivel arm can be adjusted for angle to give you maximum flexibility in positioning your
display to fit your environment and comfort level. A 180° swivel and -15° to +15° tilt capability minimizes
glare and provides comfortable viewing from multiple angles.
Durable all-metal frame with scratch-resistant powder-coated finish supports up to 33 lbs (14.9 kgs).
Comes fully assembled for quick mounting to the wall with included hardware. Conforms to VESAcompliant displays with any of the following mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 100 x 75
mm, and 100 x 100 mm.
Features
Mounts Your TV or Monitor to the WallFits most flat-panel televisions, monitors and other displays from
13 to 27 in.Ideal for home, office, hotels, bars and restaurantsFull-motion swivel arm adjusts for
angleMounting hardware included
Convenient One-Touch Adjustment180° swivel and -15° to +15° tilt capability provides comfortable
Durable Metal ConstructionSupports up to 33 lbs (14.9 kgs)Scratch-resistant powder-coated finish
blends with any décorFully assembled for immediate installation
VESA ComplianceSupports the following VESA mounting hole patterns: 75 x 75 mm, 75 x 100 mm, 100
x 75 mm, and 100 x 100 mm
Specifications
OVERVIEW
UPC Code
037332183514
1/3
Monitors
(4) M4 screws
(4) M5 screws
(4) Anchor bolts
(4) Concrete anchors
Hex key, 4 mm
Hex key, 5 mm
Owner’s manual
Device Compatibility
Monitor/HDTV
PHYSICAL
Color
Black
Material of Construction
Steel
VESA Pattern (mm)
75x75; 100x100
Motion
Full
Mounting Location
Wall
Degrees of Motion
-15/+15 Tilt; 180 Swivel
Minimum Screen Size (in.)
13
Minimum Screen Size (cm)
33.02
Maximum Screen Size (in.)
27
Maximum Screen Size (cm)
68.58
Maximum Weight Capacity (lbs.)
33
Maximum Weight Capacity (kg)
15
Min/Max Arm Extension (in.)
4.14 min to 15.95 max
Min/Max Arm Extension (cm)
10.5 min to 40 max
Number of Displays
1
Shipping Dimensions (hwd / in.)
9.40 x 2.80 x 11.00
Shipping Dimensions (hwd / cm)
23.88 x 7.11 x 27.94
Shipping Weight (lbs.)
2.75
Shipping Weight (kg)
1.25
Unit Dimensions (hwd / in.)
8.260 x 4.600 x 16.000
Unit Dimensions (hwd / cm)
21.0 x 40.49 x 11.7
Unit Weight (lbs.)
2.66
Unit Weight (kg)
1.21
FEATURES & SPECIFICATIONS
Antimicrobial
No
Cord Management
No
Tools Necessary
Yes
Security Lock
No
STANDARDS & COMPLIANCE
Product Compliance
RoHS; RoHS3; REACH
WARRANTY & SUPPORT
2/3
Product Warranty Period
(Worldwide)
5-year limited warranty
1000 Eaton Boulevard
© 2024 Eaton. All Rights Reserved.
Cleveland, OH 44122
Eaton is a registered trademark. All other trademarks
United States
are the property of their respective owners.
https://tripplite.eaton.com
3/3
很抱歉,暂时无法提供与“DWM1327SE”相匹配的价格&库存,您可以联系我们找货
