FAZ6-B16/3N
FAZ6-B16/3N
    EATON(伊顿)
    EATON MOELLER - FAZ6-B16/3N - Thermal Magnetic Circuit Breaker, 3P+N, 6kA, FAZ6, 16 A, 3 Pole, 400 V...
FAZ6-B16/3N 数据手册
DATASHEET - FAZ6-B16/3N Miniature circuit breaker (MCB), 16 A, 3p+N, characteristic: B, 6 kA Similar to illustration Part no.  Catalog No.  Alternate Catalog No.    FAZ6-B16/3N 239158 FAZ6-B16/3N Design verification as per IEC/EN 61439 Technical data for design verification       Rated operational current for specified heat dissipation In A 16 Equipment heat dissipation, current-dependent Pvid W 7.2       10.2 Strength of materials and parts       10.2.2 Corrosion resistance     Meets the product standard's requirements. 10.2.3.1 Verification of thermal stability of enclosures     Meets the product standard's requirements. 10.2.3.2 Verification of resistance of insulating materials to normal heat     Meets the product standard's requirements. 10.2.3.3 Verification of resistance of insulating materials to abnormal heat and fire due to internal electric effects     Meets the product standard's requirements. 10.2.4 Resistance to ultra-violet (UV) radiation     Meets the product standard's requirements. 10.2.5 Lifting     Does not apply, since the entire switchgear needs to be evaluated. 10.2.6 Mechanical impact     Does not apply, since the entire switchgear needs to be evaluated. 10.2.7 Inscriptions IEC/EN 61439 design verification     Meets the product standard's requirements. 10.3 Degree of protection of ASSEMBLIES     Does not apply, since the entire switchgear needs to be evaluated. 10.4 Clearances and creepage distances     Meets the product standard's requirements. 10.5 Protection against electric shock     Does not apply, since the entire switchgear needs to be evaluated. 10.6 Incorporation of switching devices and components     Does not apply, since the entire switchgear needs to be evaluated. 10.7 Internal electrical circuits and connections     Is the panel builder's responsibility. 10.8 Connections for external conductors     Is the panel builder's responsibility. 10.9 Insulation properties       10.9.2 Power-frequency electric strength     Is the panel builder's responsibility. 10.9.3 Impulse withstand voltage     Is the panel builder's responsibility. 10.9.4 Testing of enclosures made of insulating material     Is the panel builder's responsibility. 10.10 Temperature rise     The panel builder is responsible for the temperature rise calculation. Eaton will provide heat dissipation data for the devices. 10.11 Short-circuit rating     Is the panel builder's responsibility. The specifications for the switchgear must be observed. 10.12 Electromagnetic compatibility     Is the panel builder's responsibility. The specifications for the switchgear must be observed. 10.13 Mechanical function     The device meets the requirements, provided the information in the instruction leaflet (IL) is observed. Technical data ETIM 7.0 Circuit breakers and fuses (EG000020) / Miniature circuit breaker (MCB) (EC000042) Electric engineering, automation, process control engineering / Electrical installation, device / Miniature circuit breaker system (MCB) / Miniature circuit breaker (MCB) (ecl@ss10.0.1-27-14-19-01 [AAB905014]) Release characteristic     B Number of poles (total)     4 Number of protected poles     3 Rated current   A 16 Rated voltage   V 400 Rated insulation voltage Ui   V 440 Rated impulse withstand voltage Uimp   kV 4 Rated short-circuit breaking capacity Icn EN 60898 at 230 V   kA 6 Rated short-circuit breaking capacity Icn EN 60898 at 400 V   kA 6 Rated short-circuit breaking capacity Icu IEC 60947-2 at 230 V   kA 10 05/30/2020 Eaton 239158 ED2020 V68.0 EN 1/2 Rated short-circuit breaking capacity Icu IEC 60947-2 at 400 V   kA 10 Voltage type     AC Frequency   Hz 50 - 60 Current limiting class     3 Suitable for flush-mounted installation     No Concurrently switching N-neutral     Yes Over voltage category     3 Pollution degree     2 Additional equipment possible     Yes Width in number of modular spacings     4 Built-in depth   mm 70.5 Degree of protection (IP)     IP20 Ambient temperature during operating   °C -25 - 75 Connectable conductor cross section multi-wired   mm² 1 - 25 Connectable conductor cross section solid-core   mm² 1 - 25 Additional product information (links) Temperature dependency, derating 05/30/2020 https://www.eaton.com/content/dam/eaton/technicaldocumentation/technical-data-tables/Derating table FAZ6.pdf Eaton Industries GmbH http://www.eaton.eu © 05/2020 by Eaton Industries GmbH Eaton 239158 ED2020 V68.0 EN 2/2
FAZ6-B16/3N 价格&库存
很抱歉,暂时无法提供与“FAZ6-B16/3N”相匹配的价格&库存,您可以联系我们找货
