Bussmann®
Military Fuseholders
FHL10U
HGA-C
Panel Mount-Lamp Indicating
Dimensional Data
3.88"
(98.4mm)
1.19"
.81"
(30.2mm)
(20.6mm)
1.81"
(46.0mm)
Drilled Mounting Hole
Dimensional Tolerance + 0.005" (0.13 mm)
.109" RAD.
.156" DIA. + .002"
(4.0mm + .05mm)
(2.8mm)
.105" RAD.
CATALOG SYMBOL: FHL10U
LAMP INDICATING
MEETS MILITARY SPECIFICATION - MIL-F-19207/1
NO AGENCY LISTINGS
FOR MILITARY 1/4” x 1-1/4” FUSES:
F02 AND F03 SERIE
COMMERCIAL EQUIVALENT: HGA-C
(2.67mm)
.974"
(24.7mm)
.516"
(13.1mm)
.938"
.469" (23.8mm)
(11.9mm)
.433"
(11.0mm)
.437" RAD.
.400"
(11.0mm)
(10.2mm)
.800"
(20.3mm)
Specifications
Knob
Clear transparent bayonet type (fuses mount in fuse
clips of a fuse carrier)
Terminals
Threaded stud type; tooth lockwashers and hex nuts.
Enclosure
Unsealed—(FHL10U) IAW MIL-STD-108.
Panel Thickness
0.125 Max.
Rating
30 amperes. 90—250 volts.
Resistor
120,000 ohms.
Body Material
Grey; meets MIL-M-14; fire retardent IAW MIL-STD-454.
Fuse
Style MIL-F-15160 F02, F03 and MIL-F-23419/9 FM09.
Qualified and tested per MIL-F-19207. Group A, B and C.
Mechanical
Shock
MIL-STD-202. Method I.
Terminal Strength
20 lbs.
Torque
15 lbs.-inch.
The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this BIF document are by definition uncontrolled. This bulletin is intended to
clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any
products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
12-17-98
SB98107
Rev. A
Form No. FHL10U
Page 1 of 1
BIF Doc #2134
很抱歉,暂时无法提供与“FHL10U”相匹配的价格&库存,您可以联系我们找货
