Technical Data 4118
Effective October 2015
Supersedes April 2013
FP3
High current, low profile inductors
Applications
Product description
Low profile high current inductors
Inductance range 0.1μh to 15μh
Design utilizes high temperature iron powder
alloy material with a non-organic binder to
eliminate thermal aging
7.25 x 6.7mm footprint surface mount package
in a 3.0mm height
Magnetically shielded, low EMI
Current rating up to 34.7Adc (Higher peak cur
rents may be attained with a greater rolloff, see
rolloff curve)
Frequency range up to 2MHz
Voltage Regulator Modules (VRMs)
Multi-phase regulators
Desktop and server VRMs and EVRDs
Notebook and laptop regulators
Battery power systems
Graphics cards
Point-of-load modules
Environmental data
Storage temperature range (component):
-40°C to +155°C
Operating temperature range: -40°C to
+155°C (ambient plus self temperature rise)
Solder reflow temperature: J-STD-020D
Pb
FP3
Technical Data 4118
Product specifications
Part number6
OCL (uH)
± 15%
lrms2 amps
lsat3 amps 10%
lsat4 amps 15%
DCR mOhms
@ 20°C typ
DCR mOhms
@ 20°C max
K-factor5
FP3-R10-R
0.10
19.0
27
34.7
1.00
1.21
803
FP3-R20-R
0.22
15.3
16
20.8
1.54
1.88
482
FP3-R47-R
0.44
10.9
11.6
14.9
3.05
3.67
344
FP3-R68-R
0.72
9.72
9.0
11.6
3.85
4.63
268
FP3-1R0-R
1.10
6.26
7.4
9.5
9.40
11.2
219
FP3-1R5-R
1.50
5.78
6.2
8.0
10.0
13.1
185
FP3-2R0-R
2.00
5.40
5.4
6.9
11.5
15.0
161
FP3-3R3-R
3.20
3.63
4.3
5.5
24.5
30.0
127
FP3-4R7-R
4.70
3.23
3.5
4.2
34.9
40.0
105
FP3-8R2-R
8.5
2.91
2.6
3.4
61.6
74.0
78
FP3-100-R
10.9
2.30
2.3
3.0
84.2
101
69
FP3-150-R
14.9
2.22
2.0
2.5
106.0
127
59
5. K-factor: Used to determine Bp-p for core loss (see graph). Bp-p =K*L*ΔI.
Bpp: (Gauss), K: (K factor from table), L: (Inductance in μH), ΔI (Peak to peak ripple
current in Amps).
6. Part number definition:
FP3 = product code and size
xxx = inductance value in μH
R = decimal point (if no “R” is present, then last character equals the number of zeros)
“-R” suffix = RoHS complaint
1. OCL (Open Circuit Inductance) Test parameters: 100kHz, 0.1Vrms, 0.0Adc
2. Irms DC current for an approximate ΔT of 40°C without core loss. Derating is
necessary for AC currents. PCB layout, trace thickness and width, air-flow, and
proximity of other heat generating components will affect the temperature rise.
It is recommended that the temperature of the part not exceed 155°C under
worst case operating conditions verified in the end application.
3. Isat Amps Peak for approximately 10% rolloff @ 20°C
4. Isat Amps Peak for approximately 15% rolloff @ 20°C
Dimensions–mm
RECOMMENDED PAD LAYOUT
2.80 ±0.25
FP3
XXX
YWWL
3.00 Max
SCHEMATIC
1
(2x)
2.80 ±0.25
1.0 min.
(2x)
1
7.25
Max
7.50
2.50 (2x)
2
6.70
Max
(2x)
2
4.50 (2x)
Part marking: FP3 (Product code and size), xxx=(inductance value in µH),
R=decimal point (if no “R” is present, then last character equals the number of zeroes, YWW=Date code, L=Location code
Packaging information (mm)
Supplied in tape and reel packaging, 1700 parts per 13” diameter reel
1.5 Dia
1.5 Dia
4.0
2.0
1.75
A
1
FP3
XXX
YWWL
7.5
2
A
6.9
3.2
SECTION A-A
2
www.eaton.com/elx
12.0
Direction of Feed
7.5
16.0
+/-0.3
FP3
Technical Data 4118
Inductance characteristics
OCL vs. Isat
100
90
% of OCL
80
70
60
50
40
30
60
80
100
120
140
160
180
200
% of Isat
Core Loss (W)
Core loss
1.00
0.90
0.80
0.70
0.60
0.50
0.40
0.30
0.20
0.10
0.00
250
Frequency (kHz)
200
300
400
500
600
700
800
500
750
900
1000 1250 1500 1750 2000 2250
1000
B p-p (Gauss)
Temperature Rise (°C)
Temperature rise vs. total loss
140
130
120
110
100
90
80
70
60
50
40
30
0.24
0.36
0.48
0.61
0.73
0.85
0.97
1.09
1.21
1.33
1.45
1.57
Total Loss (W)
www.eaton.com/elx
3
FP3
Technical Data 4118
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FP3-8R2-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+33.796571+4.38353
- 10+30.5669810+3.96464
- 25+30.2606525+3.92491
- 100+17.81489100+2.31065
