Technical Data 10389
Effective April 2016
Supersedes May 2015
FPT1006
Dual conductor high current power inductors
Applications
Compatible with Picor® Cool-Power®
ZVS Buck and Buck-Boost Regulator Families
Environmental Data
Description
Dual conductor, two-turn construction
Magnetically shielded
Inductance range from 340 nH to 580 nH
Current range from 19 A to 40.5 A
10.5 mm x 8.8 mm footprint surface mount
package in a 6.4 mm height
Ferrite core material
Halogen free, lead free, RoHS compliant
Storage temperature range (component):
-55 °C to +125 °C
Operating temperature range (component):
-55 °C to +125 °C (ambient plus
self-temperature rise)
Solder reflow temperature: J-STD-020D
compliant
HALOGEN
Pb HF
FREE
Picor® and Cool-Power® are trademarks of Vicor Corporation.
FPT1006
Product Specifications
OCL1
(nH) ±10%
Irms2
(A)
Isat3
(A)
DCR4 (mΩ)
maximum
@ 20°C
FPT1006-340-R
340
19
40.5
1.0
FPT1006-400-R
400
19
35.5
1.0
FPT1006-500-R
500
19
27.5
1.0
FPT1006-580-R
580
19
23.0
1.0
Part Number
5
1. Open Circuit Inductance (OCL) Test Parameters: 100 kHz, 0.1 Vrms, 0.0 Adc, +25 °C (Pins 4-2, short 1-3)
2. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
3. Isat : Peak current for approximately 5% rolloff @ +25 °C
4. DCR tested from pins (1-2) and (3-4)
5. Part Number Definition: FPT1006-xxx-R
FPT1006 = Product code and size
xxx = Inductance value in nH,
-R suffix = RoHS compliant
Note: Hipot: 250 Vdc minimum for 2 seconds, 1.0 mA pins (1-2) and pins (4-3) to core
Dimensions (mm)
2.8
±0.2
10.0
±0.5
6.4
max
9.65
±0.3
Recommended Pad Layout
FPT1006-XXX
wwllyy R
4
1
4
3 8.5
2 ±0.3
0.5
1.2
Part marking: FPT1006-xxx, xxx = inductance value in nH,
wwllyy=date code, R=revision level
Tolerances are ±0.25 unless stated otherwise
All mounting surfaces to be coplanar within 0.102 mm
2
www.eaton.com/elx
Resist area
3.0
0.4
1.5
Schematic
1
4
2
3
3
1
2
0.56
10.0
1.5
Pins 1 and 3 connected through
PCB trace
FPT1006
Packaging information (mm)
Supplied in tape and reel packaging, 620 parts per 13” diameter reel
4.0
1.5 dia
1.5 dia
2.0
A
1
1.75
4
11.5
24.0
±0.3
FPT1006–xxx
wwllyy R
9.7
2
3.4
A
8.5
6.6
Section A – A
3
16.0
Direction of feed
Inductance characteristics
FPT1006-340-R
FPT1006-400-R
110%
110%
100%
100%
-40°C
80%
+25°C
70%
+125°C
60%
-40°C
90%
% of OCL
% of OCL
90%
80%
60%
50%
50%
40%
40%
30%
30%
40
50
60
10
15
lDC (A)
25
30
35
40
45
50
55
lDC (A)
FPT1006-500-R
FPT1006-580-R
110%
110%
100%
100%
-40°C
90%
+125°C
+25°C
80%
% of OCL
90%
% of OCL
+25°C
+125°C
70%
70%
60%
+125°C
70%
+25°C
60%
50%
50%
40%
40%
30%
-40°C
80%
30%
10
15
lDC (A)
30
35
40
45
10
15
30
35
40
lDC (A)
www.eaton.com/elx
3
FPT1006
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb Solder (Tc)
Package
Thickness
Volume
mm3
很抱歉,暂时无法提供与“FPT1006-340-R”相匹配的价格&库存,您可以联系我们找货
