Bussmann
FWP 700V
Type
5-1200A
R
Electrical Characteristics
Ordering Information
I2t (A2 Sec)
Rated
Current
Clearing
Watts
Part
Carton
RMS-Amps
Pre-arc
at 700V
Loss
Number
Qty.
5
1.6
10
1.5
FWP-5B
__________________________________________________________________________
10
3.6
FWP-10B
15
10
75
5.5
FWP-15B
180
6
FWP-20B
25
44
340
7
FWP-25B
10
Dimensions
Carton
Weight
(lbs)
Figure
Number
2.25
Curves
BIF #
35785316
30
58
450
9
FWP-30B
______________________________________________________________________________________
____________
35
34
160
12
FWP-35B
40
76
320
12
FWP-40B
50
135
600
12
FWP-50B
5
1.21
60
210
950
15.5
FWP-60B
_________________________________________________________________________________________________
35785308
70
305
2000
18
FWP-70B
80
360
2400
21
FWP-80B
0.24
90
415
2700
25
FWP-90B
100
540
3500
27
FWP-100B
____________
125
1800
7300
28
FWP-125A
FWP
150
2900
11700
32
FWP-150A
Fig. 1
0.65
700V __________________________________________________________________________
175
4200
16700
35
FWP-175A
200
5500
22000
43
FWP-200A
____________
225
7700
31300
45
FWP-225A
361
250
10500
42500
48
FWP-250A
300
17600
71200
58
FWP-300A
1
1.17
350
23700
95600
65
FWP-350A
400
31000
125000
78
FWP-400A
____________
450
36400
137000
94
FWP-450A
500
45200
170000
107
FWP-500A
2.39
600
66700
250000
122
FWP-600A
____________
700
54000
300000
125
FWP-700A
800
78000
450000
140
FWP-800A
1.21
900
91500
530000
150
FWP-900A
1000
120000
600000
170
FWP-1000A
1200
n
n
n
n
195000
1100000
190
FWP-1200A
6.60
Fig. 2
Fig. 3
Interrupting rating 200kA RMS Symmetrical.
1 kg = 2.2 lbs
Watts loss provided at rated current.
(700 Vdc/Interrupting rating 50kA) U.L. Recognition & CSA Component Acceptance on 5 through 100 & 700 through 800 amperes.
(700 Vdc/Interrupting rating 10kA) U.L. Recognition & CSA Component Acceptance on 125 through 600 amperes.
3-6-02
A02008
35785308
___________
1 lb = 0.45 kg
Form No. FWP 700
Page 1 of 2
Data Sheet: 720012
Bussmann
5-1200A
FWP 700V
R
Total Clearing I2t
The total clearing I2t at rated voltage and
at power factor of 15% are given in the
electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K , given as
a function of applied working voltage,
E g , (RMS).
Arc Voltage
This curve gives the peak arc voltage,
U L , which may appear across the fuse
during its operation as a function of the
applied working voltage, E g , (RMS) at a
power factor of 15%.
2
1.5
1.0
Kp
0.8
UL
K
1.6
1.4
1.2
103
1.0
2)
0.5
0.6
0.5
1)
0.4
2)
8
0.3
0.2
0.3
6
5
1)
3)
Power Losses
Watts loss at rated current is given in
the electrical characteristics. The curve
allows the calculation of the power
losses at load currents lower than the
rated current . The correction factor, K p ,
is given as a function of the RMS load
current, Ib , in % of the rated current .
0.2
4
0.15
316
Eg
460
604
Eg
3
300
700
1) 35-100 Amp Range
2) 125-600 Amp Range
3) 700-1200 Amp Range
400
500
600
Ib
0.1
30 40 50
700
60
70
80 90 100%
1) 125-600 Amp Range
2) 35-100 & 700-1200 Amp Range
Dimensions
Fig. 1: 5-800 Amp Range
Fig. 2: 900-1000 Amp Range
Fig. 3: 1200 Amp Range
3.500
1.375
J
0.125
0.500
5.966
7.594
A D E C
9.590 6.840
3.844
3.844
10.844
5.154
1.031
0.625
1.625
1.750
0.625
2.750
0.750
0.500
4.250
F
3.500
G
H
B
Order #
Fig.
A
B
C
D
E
F
G
H
J
FWP-5B-30B
1
2.870
0.563
1.855
2.477
2.477
0.250
0.405
0.063
0.250
FWP-35B-60B
1
4.375
0.813
2.750
3.708
3.312
0.344
0.725
0.125
0.542
FWP-70B-100B
1
4.406
0.947
2.594
3.625
3.563
0.344
0.750
0.125
0.375
FWP-125A-200A
1
5.090
1.500
2.840
4.190
3.500
0.410
1.000
0.250
0.750
FWP-225A-400A
1
5.090
2.000
2.840
4.280
3.530
0.410
1.500
0.250
0.780
FWP-450A-600A
1
7.090
2.500
2.840
5.720
4.190
0.530
2.000
0.380
1.300
FWP-700A-800A
1
6.630
2.000
2.844
5.562
5.062
0.625
1.500
0.250
0.875
FWP-900A-1000A
2
See Drawing
FWP-1200A
3
See Drawing
Dimension in inches.
1mm = 0.0394∑
1∑ = 25.4mm
The only controlled copy of this BIF document is the electronic read-only version located on the Bussmann Network Drive. All other copies of this document are by definition uncontrolled.
This bulletin is intended to clearly present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right,
without notice, to change design or construction of any products and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without
notice, any technical information contained in this bulletin. Once a product has been selected, it should be tested by the user in all possible applications.
3-6-02
A02008
Form No. FWP 700
Page 2 of 2
Data Sheet: 720012
很抱歉,暂时无法提供与“FWP-125A”相匹配的价格&库存,您可以联系我们找货
