FWP-63A22F
FWP-63A22F
    EATON(伊顿)
    Cartridge,Non-Standard
    FUSE CARTRIDGE 63A 700VAC/500VDC
FWP-63A22F 数据手册
High Speed Fuses Ferrule — FWP 690V/700V (IEC/UL): 1-50A, Striker Optional FWP (14 x 51mm) Arc Voltage Specifications Description: Ferrule style high speed fuses with and without indicating striker. Dimensions: See dimensions illustrations. Ratings: Volts: — 690Vac (IEC) — 700Vac (UL) FWP with — 800Vdc (5-50A) striker option. Amps: — 1-50A IR: — 200kA RMS Sym. — 50kA @800Vdc Agency Information: CE, UL Recognition JFHR2.E91958, CSA Component Acceptance file Class 1422-30, 1422-90 (53787) for versions without indicator only. Designed and tested to IEC 60269: Part 4. Electrical Characteristics Total Clearing I2t 1.4 1.2 1.0 0.9 0.8 0.7 0.6 The total clearing I2t at rated voltage and at power factor of 15% are given in 0.5 the electrical 1) characteristics. For other 0.4 2) voltages, the clearing I2t is 0.3 found by multiplying by 200 correction factor, K, given as a function of applied working voltage, Eg, (rms). 1.4 1.2 103 9 8 7 6 Power Losses 3 Catalog Numbers 300 400 500 1) 5-30A Range 2) 32-50A Range 600 Eg 700 Without Striker 50.8 (2.000") 14.3 (0.563") 15.5 (0.610") With Striker 5 (0.197") Size 51 (2.00") 13 (0.511") • • • • 4 200 1.0 Kp 0.8 300 400 500 600 Eg 700 0.6 0.5 0.4 0.3 0.2 Ib 0.1 30 40 50 60 70 80 90 100% Electrical Characteristics Rated I2t (A2 Sec) Current Minimum Clearing At Watts RMS-Amps Melting Rated Voltage Loss 14 x 51mm (9⁄16" x 2") 14 x 51mm (9⁄16” x 2”) *Striker range is 600Vdc only • Watts loss provided at rated current. • See accessories on page 243. 59 (2.323") 14.3 (0.563") Catalog Numbers Without Striker FWP-1A14F FWP-2A14F FWP-2.5A14F FWP-3A14F FWP-4A14F FWP-5A14F FWP-10A14F FWP-15A14F FWP-20A14F FWP-25A14F FWP-30A14F FWP-32A14F FWP-40A14F FWP-50A14F With Striker* FWP-10A14FI FWP-15A14FI FWP-20A14FI FWP-25A14FI FWP-30A14FI FWP-32A14FI FWP-40A14FI FWP-50A14FI UL 5 Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, Kp, is given as a function of the RMS load current, Ib, in % of the rated current. K Dimensions - mm (in) 234 This curve gives the peak arc voltage, UL, which may appear across the fuse during its operation as a function of theapplied working voltage, Eg, (rms) at a power factor of 15%. 1 2 2.5 3 4 5 10 15 20 25 30 32 40 50 10 15 20 25 30 32 40 50 — — — — — 1.6 3.6 8.6 26.0 46.5 58 68 84 200 3.6 8.6 26.0 46.5 58 68 84 200 — — — — — 11.0 38.5 70 230 375 485 600 750 1800 38.5 70 230 375 485 600 750 1800 Features and Benefits Excellent cycling capability and DC performance Low arc voltage and low energy let-through (I2t) Low watts loss in a compact size Used with finger-safe holders/blocks Data Sheet: 720025 For product data sheets, visit www.cooperbussmann.com/DatasheetsEle — — — — — 1.5 4 5.5 6 7 9 7.6 8 9 4 5.5 6 7 9 7.6 8 9 High Speed Fuses Ferrule — FWP 690V/700V (IEC/UL): 1-50A, Striker Optional Without Striker FWP 5-50A: 660V/700V (14 x 51mm) Time-Current Curve 104 6 4 2 103 6 4 2 Virtual Pre-Arcing Time In Seconds 102 FWP-25A14F FWP-30A14F FWP-32A14F FWP-40A14F FWP-50A14F 6 4 2 101 6 4 2 100 10–1 6 4 FWP-5A14F FWP-10A14F FWP-15A14F FWP-20A14F 2 6 4 2 10–2 6 4 2 10–3 6 4 2 10–4 2 4 6 8 2 101 4 6 8 2 102 4 6 8 103 High Speed Fuses Prospective Current In Amps RMS Peak Let-Through Curve 104 FWP-50A14F FWP-40A14F FWP-32A14F FWP-30A14F FWP-25A14F 6 4 2 Peak Let-Through Current 103 6 4 2 FWP-20A14F FWP-15A14F FWP-10A14F FWP-5A14F 102 6 4 2 101 101 2 4 6 102 2 4 6 103 2 4 6 104 Prospective Short-Circuit Current Symmetrical RMS 2 4 6 105 2 Data Sheet: 35785307 For product data sheets, visit www.cooperbussmann.com/DatasheetsEle 235 High Speed Fuses Ferrule — FWP 690V/700V (IEC/UL): 20-100A, Striker Optional FWP (22 x 58mm) This curve gives the peak arc voltage, UL, which may appear across the fuse during its operation as a function of theapplied working voltage, Eg, (rms) at a power factor of 15%. Specifications Description: Ferrule style high speed fuses with and without indicating striker. Dimensions: See dimensions illustration. Ratings: Volts: — 690Vac (IEC) — 700Vac (UL) FWP with — 500Vac striker option. — 500Vdc (20-100A) Amps: — 20-100A IR: — 200kA RMS Sym. — 50kA @ 500Vdc Agency Information: CE, UL Recognition JFHR2.E91958, CSA Component Acceptance file Class 1422-30, 1422-90 (53787) Electrical Characteristics Total Clearing I2t The total clearing I t at rated voltage and at power factor of 15% are given in the electrical characteristics. For other voltages, the clearing I2t is found by multiplying by correction factor, K, given as a function of applied working voltage, Eg, (rms). 2 1.4 1.2 1.0 0.9 0.8 0.7 0.6 Power Losses Watts loss at rated current is given in the electrical characteristics. The curve allows the calculation of the power losses at load currents lower than the rated current. The correction factor, Kp, is given as a function of the RMS load current, Ib, in % of the rated current. K 0.5 0.4 0.3 200 300 58.0 (2.283") 400 500 22.2 (0.875") 600 Eg 700 Catalog Numbers Without Striker FWP-20A22F FWP-25A22F FWP-32A22F FWP-40A22F FWP-50A22F FWP-63A22F FWP-80A22F FWP-100A22F With Striker FWP-20A22FI FWP-25A22FI FWP-32A22FI FWP-40A22FI FWP-50A22FI FWP-63A22FI FWP-80A22FI FWP-100A22FI Size 22 x 58mm (7⁄8" x 29⁄32") 22 x 58mm (7⁄8" x 29⁄32") *IEC/UL Voltage rating 690/700 15.0 (0.591") With Striker 66 (2.598") 58 (2.283") 5 (0.197") 22.2 (0.874") UL 5 4 3 200 1.0 Kp 0.8 400 500 600 700 0.6 0.5 0.4 0.3 0.2 0.1 30 40 50 16 (0.630" • • • • • • • • Rated Current RMS-Amps 20 25 32 40 50 63 80 100* 20 25 32 40 50 63 80 100* 60 70 Ib 80 90 100% Electrical Characteristics I2t (A2 Sec) Minimum Clearing At Melting Rated Voltage Watts Loss 19.0 34.0 53.5 68 135 280 600 1100 5 6 8 9 9.5 11 13.5 16 19.0 34.0 53.5 68 135 280 600 1100 260 410 605 750 1600 3080 6600 12500 260 410 605 750 1600 3080 6600 12500 Features and Benefits Excellent cycling capability and DC performance Low arc voltage and low energy let-through (I2t) Low watts loss in a compact size Used with finger-safe holders/blocks Typical Applications DC Common bus DC Drives Power converters/rectifiers Reduced voltage starters Data Sheet: 720026 236 300 Eg Catalog Numbers Dimensions - mm (in) Without Striker 1.4 1.2 103 9 8 7 6 Arc Voltage For product data sheets, visit www.cooperbussmann.com/DatasheetsEle 5 6 8 9 9.5 11 13.5 16 High Speed Fuses Ferrule — FWP 690V/700V (IEC/UL): 20-100A, Striker Optional Without Striker FWP 20-100A: 660V/700V (22 x 58mm) Time-Current Curve 104 6 4 2 103 6 4 2 102 FWP-50A22F FWP-63A22F FWP-80A22F FWP-100A22F 6 4 2 Virtual Pre-Arcing Time In Seconds 101 6 4 2 10 0 6 4 FWP-20A22F FWP-25A22F FWP-32A22F FWP-40A22F 2 10–1 6 4 2 10–2 6 4 2 10–3 6 4 2 2 101 4 6 8 2 102 4 6 8 High Speed Fuses 10–4 103 Prospective Current In Amps RMS Peak Let-Through Curve 104 FWP-100A22F FWP-80A22F 6 FWP-63A22F Peak Let-Through Current 4 FWP-50A22F 2 103 6 FWP-40A22F FWP-32A22F 4 FWP-25A22F FWP-20A22F 2 102 102 2 4 6 103 2 4 6 104 2 Prospective Short-Circuit Current Symmetrical RMS 4 6 105 2 Data Sheet: 35785291 For product data sheets, visit www.cooperbussmann.com/DatasheetsEle 237
FWP-63A22F 价格&库存
很抱歉,暂时无法提供与“FWP-63A22F”相匹配的价格&库存,您可以联系我们找货
