BK-S505H-V-15-R
BK-S505H-V-15-R
    EATON(伊顿)
    插件,D6xL22.5mm
    一次性保险丝(熔断) 15A 400V
BK-S505H-V-15-R 数据手册
Effective June 2023 Supersedes November 2021 Technical Data 4406 S505H 5 mm x 20 mm 400 Vdc/500-600 Vac time-delay fuse Applications Product features • 400 Vdc/500-600 Vac rating • Time-delay, high breaking capacity • 5 mm x 20 mm physical size • Ceramic tube with plated end cap construction • Designed to IEC 60127-2, Standard, Sheet 5 • Optional axial leads available • Fuse accesories guide (holders, clips) Ordering part number The ordering code is the part number replacing the “.” with a “-” • Power supplies - adapters • Desktops/notebooks • TVs / Displays • Set top boxes • Lighting ballasts • Battery chargers • Printers • Game systems • Air conditioners Agency information S505H-XXX-R (Cartridge) • • • • • BK-S505H-V-6-3-R cURus Recognition file: E56412, Guide JFHR2,JFHR8, (500 mA - 10 A); E19180, Guide JDYX2 and JDYX8, (12 A - 20 A) CCC Approval: 500 mA - 10 A, Cert. No.: 2020970207000249 TUV Approval: 2 A - 10 A, Cert. No.: R50297821 PSE Approval: 1 A - 5 A, Cert. No.: JET164131003-1025; 6.3 A - 10 A JET1641-31003-1023 KC Approval: SU05011-21001A (1 A - 2.5 A), SU05011-21002A (3.15 A - 6.3 A), SU0501121003A (8 A -10 A), SU05011-21004A (500 mA - 800 mA) S505H-V-XXX-R (Axial leads) Packaging prefix Family name Option code (V = axial leaded) Ampere rating • • RoHS compliance Packaging prefix • • Blank: 5 cartridge parts in a 5 inch tin, 4 axial lead parts in a 5 inch tin) (Values < 12 A only) • • BK-: 100 parts packed in a cardboard carton (axial leaded only) • • BK1-: 1000 parts in a poly bag (cartridge version only) • TR2- 1500 parts on a reel (axial lead V option only, values < 12 A only) cURus Recognition file: E56412, Guide JFHR2,JFHR8, (500 mA - 10 A) E19180, Guide JDYX2 and JDYX8, (12 A - 20 A) PSE Approval: 1 A - 5 A, Cert. No.:JET164131003-1026; 6.3 A - 10 A, Cert. No: JET1641-31003-1024 CCC Approval: 500 mA - 10 A, Cert. No.: 2020970207000249 TUV Approval: 500 mA-10 A, Cert. No.: R50297821 KC Approval: SU05011-21001A (1 A - 2.5 A), SU05011-21002A (3.15 A - 6.3 A), SU0501121003A (8 A -10 A), SU05011-21004A (500 mA - 800 mA) Option code • -V : (Axial leads – copper tinned wire with nickel plated brass end caps) Environmental compliance HALOGEN Pb HF FREE S505H 5 mm x 20 mm 400 Vdc/500-600 Vac time-delay fuse  Technical Data 4406 Effective June 2023 Electrical characteristics Amp Rating 1.5 In minimum minutes 2.1 In maximum minutes 2.75 In minimum ms maximum seconds 4.0 In minimum ms maximum seconds 10 In mimimum ms maximum ms 500 mA - 1 A 60 30 250 80 50 5 5 150 1 A - 3.15 A 60 30 750 80 95 5 10 150 4 A -6.3 A 60 30 750 80 150 5 10 150 8 A -10 A 30 30 750 80 150 5 10 150 12 A - 20 A 30* 30 750 80 150 8 10 150 * 1.5 In rating for cartridge version only Product specifications Part number Current rating (A) Voltage rating1 (Vac) (Vdc) Interrupting rating @ rated voltage (A) @ (A) @ (A) @ 250 Vac2 600 Vac3 400 Vdc4 Typical DC cold resistance5 (Ω) Typical voltage drop6 (mV) Typical melting7 I2t (A2s) S505H(-V)-500-R 0.5 600 400 1500 100 1500 0.507 295 S505H(-V)-800-R 0.8 600 400 1500 100 1500 0.237 189 S505H(-V)-1-R 1 600 400 1500 100 1500 0.157 S505H(-V)-1.25-R 1.25 600 400 1500 100 1500 0.108 S505H(-V)-1.6-R 1.6 600 400 1500 100 1500 S505H(-V)-2-R 2 600 400 1500 100 1500 S505H(-V)-2.5-R 2.5 600 400 1500 100 1500 Agency approvals 250 Vac Tuv CCC PSE/JET cURus9 0.188 8 x x x 0.632 x8 x x 176 1.28 8 x x x x 150 2.22 x8 x x x 0.070 125 6.78 x x x x 0.055 128 11.44 x x x x 0.040 126 24.23 x x x x 8 S505H(-V)-3.15-R 3.15 600 400 1500 100 1500 0.031 121 43.55 x x x x S505H(-V)-4-R 4 600 400 1500 100 1500 0.019 90 38.45 x x x x S505H(-V)-5-R 5 600 400 1500 100 1500 0.015 89 71.30 x x x x S505H(-V)-6.3-R 6.3 500 400 1500 100 @ 500 Vac 1500 0.011 80 111.4 x x x x S505H(-V)-8-R 8 500 400 1500 100 @ 500 Vac 1500 0.007 76 228.2 x x x x S505H(-V)-10-R 10 500 400 1500 100 @ 500 Vac 1500 0.006 72 349.5 x x x x S505H(-V)-12-R 12 500 400 na 200 @ 500 Vac 300 0.00545 80 550 x S505H(-V)-15-R 15 500 400 na 200 @ 500 Vac 300 0.004 75 900 x S505H(-V)-16-R 16 500 400 na 200 @ 500 Vac 300 0.0037 68 1100 x S505H(-V)-20-R 20 500 na na 200 @ 500 Vac na 0.00325 75 1500 x 1. Voltage rating: based on the interrupting rating test according to UL. 2. Interrupting rating of 250 Vac/1500 A is tested by all agency approvals, test condition is 250 Vac, PF: 0.7 - 0.8. 3. Interrupting rating of Vac is tested with, PF:1.0 (500 mA - 5 A @ 600 Vac, 6.3 A - 20 A @ 500 Vac) 4. Interrupting rating of Vdc is tested under capacitor bank for 500 mA to 10A; Vdc interrupting rating for 12 A– 20 A is tested under power supply with time constant less than 1 ms. 2 www.eaton.com/electronics 5. Typical cold resistance measured at
BK-S505H-V-15-R 价格&库存
很抱歉,暂时无法提供与“BK-S505H-V-15-R”相匹配的价格&库存,您可以联系我们找货
