C22-WRK-K11-P62
C22-WRK-K11-P62
    EATON(伊顿)
    EATON CUTLER HAMMER - C22-WRK-K11-P62 - ROTARY SWITCH, 2P, 2 POS, 4A, 24VAC
C22-WRK-K11-P62 数据手册
DATASHEET - C22-WRK-K11-P62 Changeover switch, classic, with thumb-grip, maintained, 2 positions, 1 N/C, 1 N/O, cable (black) with non-terminated end, 4 pole, 1 m Delivery program Part no.  Catalog No.      C22-WRK-K11-P62 186164 Product range     RMQ compact solution Basic function     Selector switch actuators Single unit/Complete unit     Complete unit Design     With thumb-grip       maintained Function:           Connection type     Cable (black) with non-terminated end, 4 pole Cable Length   m 1       2 positions Degree of Protection     IP66 (front) IP65 (on rear) Front ring     Bezel: titanium Connection to SmartWire-DT     no Contacts       N/C = Normally closed     N/O = Normally open     Notes             mm   4.65 Maximum travel mm   5.7 Minimum force for positive opening 20   Actuator travel and actuation force as per DIN EN 60947-5-1, K.5.4.1 60° 1 NC 1 N/O = safety function, by positive opening to IEC/EN 60947-5-1 N   Contact sequence     Contact travel■ = Contact closed□ = Contact open             yes Standards     IEC/EN 60947-5-1 VDE 0660 Certifications     CE, UL, CSA 03/19/2018 Eaton 186164 ED2018 V42.0 EN Contact diagram Positive opening (ZW)   Technical data General 1/3 Operating frequency Operations/h   ≦ 2000 Operating torque   Nm ≦ 0.3 Tightening torque Threaded ring   Nm 2 Climatic proofing     Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclic, to IEC 60068-2-30 Degree of Protection     IP66 (front) IP65 (on rear) Mounting position     As required Mechanical shock resistance, shock duration 11 ms   g > 30 Rated impulse withstand voltage Uimp V AC 800 Rated insulation voltage Ui V 30 Overvoltage category/pollution degree     III/3 Control circuit reliability       HF   N/O contact: statistically determined 1 failure per 17 × 106 operations       gG/gL A 4 Rated conditional short-circuit current Iq kA 1 Rated operational current Ie A         Ie A 4       Ie A 3       Design     Cable end open Cable Length   m 1 Material characteristic     PUR Diameter ⌀ mm 4.7       Operating ambient temperature min.   °C -25 Operating ambient temperature max.   °C 70 Contacts At 17 V DC/7 mA Max. short-circuit protective device Fuse Switching capacity AC-15 24 V DC-13 24 V Cable characteristics Design verification as per IEC/EN 61439 Technical data for design verification 6 N/C contact: statistically determined 1 failure per 0.9 × 10 Operations Technical data ETIM 6.0 Low-voltage industrial components (EG000017) / Selector switch, complete (EC001029) Electric engineering, automation, process control engineering / Low-voltage switch technology / Command and alarm device / Selector switch, complete unit (ecl@ss8.1-27-37-12-43 [ACN984008]) Number of switch positions     2 Type of control element     Toggle Suitable for illumination     No With lamp     No Colour button     Black Hole diameter   mm 22 Width opening   mm 0 Height meter opening   mm 0 Switching function latching     Yes Spring-return     No Degree of protection (IP)     IP66 Supply voltage   V 0-0 Number of contacts as normally open contact     1 Number of contacts as normally closed contact     1 Number of contacts as change-over contact     0 Type of electric connection     Other With front ring     Yes 03/19/2018 Eaton 186164 ED2018 V42.0 EN 2/3 Material front ring     Plastic Colour front ring     Other Dimensions Assets (Links) Declaration of Conformity 00002596 Additional product information (links) IL047016ZU RMQ compact solution IL047016ZU RMQ compact solution 03/19/2018 ftp://ftp.moeller.net/DOCUMENTATION/AWA_INSTRUCTIONS/IL047016ZU2017_01.pdf Eaton Industries GmbH http://www.eaton.eu © 03/2018 by Eaton Industries GmbH Eaton 186164 ED2018 V42.0 EN 3/3
C22-WRK-K11-P62 价格&库存
很抱歉,暂时无法提供与“C22-WRK-K11-P62”相匹配的价格&库存,您可以联系我们找货
