Bussmann®
Tron Time-Delay Fuses
FNQ
13/32∑ x 1-1/2∑ Midget
500 Volt, 1/10-30 Amps
• Fibre tube.
• Nickel plated brass endcaps.
• For motor control transformers and other circuits with in-rush
currents.
1.5"
(50.031)
38.1mm
15
30
4
5
6
7
10
3-2/10
300
100
1/2
.41"
(50.004)
10.3mm
1-6/10
2
1
Time-Current Characteristic Curve–Average Melt
100
FNQ-5
FNQ-15
FNQ-1/4
FNQ-1-6/10
FNQ-5-6/10
FNQ-20
FNQ-3/10
FNQ-2
FNQ-6
FNQ-25
FNQ-4/10
FNQ-2-1/4
FNQ-6-1/4
FNQ-30
FNQ-1/2
FNQ-2-1/2
FNQ-7
FNQ-6/10
FNQ-3
FNQ-8
Carton Quantity and Weight
Carton
Qty
Weight*
Lbs.
Kg.
10
.180
.082
* Weight per carton.
.01
CURRENT IN AMPERES
.01
600
FNQ-1-1/2
200
FNQ-14
FNQ-2/10
100
FNQ-4-1/2
FNQ-1-1/4
10
FNQ-12
FNQ-3/16
6
FNQ-4
200
FNQ-1-1/8
100
FNQ-10
FNQ-15/100
FNQ-9
FNQ-3-1/2
10
FNQ-3-2/10
FNQ-1
1-30
.1
1
FNQ-8/10
FNQ-1/8
.6
FNQ-1/10
1
1
.1
Catalog Symbol and Ampere Ratings
Ampere
Ratings
10
TIME IN SECONDS
Catalog Symbol: FNQ (5AG)
TIME-DELAY
1/10 TO 30A
500Vac (OR LESS)
Interrupting Rating:10,000A
UL LISTED, STD 248-14, (GUIDE # JDYX, FILE # E19180)
CSA CERTIFIED (CLASS 1422-01; FILE 53787)
TIME IN SECONDS
10
CURRENT IN AMPERES
RMS SYMMETRICAL IN AMPERES
Recommended fuseblocks/fuseholders for
13/32” x 1-1/2” fuses
See Data Sheets listed below
• Open fuseblocks - 1104, 2104
• Finger-safe fuseholders - 1109, 1102, 1103, 1151
• Panel-mount fuseholders - 2114, 2113, 2108,
2112, 2109, 2140
• In-line fuseholders - 2127, 2126
CE logo denotes compliance with European Union Low Voltage Directive
(50-1000Vac, 75-1500Vdc). Refer to Data Sheet: 8002 or contact
Bussmann Application Engineering at 636-527-1270 for more information.
The only controlled copy of this Data Sheet is the electronic read-only version located on the Bussmann Network Drive. All other copies of this Data Sheet are by definition uncontrolled. This bulletin is intended to clearly
present comprehensive product data and provide technical information that will help the end user with design applications. Bussmann reserves the right, without notice, to change design or construction of any products
and to discontinue or limit distribution of any products. Bussmann also reserves the right to change or update, without notice, any technical information contained in this bulletin. Once a product has been selected, it
should be tested by the user in all possible applications.
10-2-02
SB02295
Form No. FNQ
Page 1 of 1
Data Sheet: 1012
很抱歉,暂时无法提供与“FNQ-5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+646.94376
- 50+629.47983
- 250+606.47010
