productinformation
tesa® 4952
Double-sided PE-foam mounting tape
tesa® 4952 is a double-sided PE-foam tape for constructive mounting applications. It consists of a highly conformable PE-foam
backing and a tackified acrylic adhesive. tesa® 4952 has been externally certified for furniture mirror mounting.
Product benefits:
Versatile adhesive for high immediate adhesion on numerous substrates
Fully outdoor suitable: UV, water and ageing resistant
Compensates for differing thermal expansion of dissimilar materials
High immediate bonding strength even at low bonding pressure
Very good cold shock absorbtion
Main Application
Furniture mirror mounting
Mounting of car mirrors
Mounting functional trims & profiles
Mounting of decorative panels
Technical Data
Backing material
Color
Total thickness
Type of adhesive
Elongation at break
PE foam
white
1150 µm
tackified acrylic
200 %
Tensile strength
Type of liner
Colour of liner
Thickness of liner
Weight of liner
Steel (after 14 days)
ABS (after 14 days)
Aluminium (after 14 days)
PC (after 14 days)
PE (after 14 days)
PET (after 14 days)
PP (after 14 days)
PS (after 14 days)
PVC (after 14 days)
10 N/cm
glassine
brown
70 µm
80 g/m²
Adhesion to
Steel (initial)
ABS (initial)
Aluminium (initial)
PC (initial)
PE (initial)
PET (initial)
PP (initial)
PS (initial)
PVC (initial)
6.5 N/cm
5.0 N/cm
5.0 N/cm
5.0 N/cm
2.7 N/cm
5.0 N/cm
2.8 N/cm
5.0 N/cm
5.0 N/cm
8.0 N/cm
8.0 N/cm
8.0 N/cm
8.0 N/cm
2.8 N/cm
7.0 N/cm
5.5 N/cm
7.5 N/cm
8.0 N/cm
Page 1 of 2 - as of 16/10/2019 - ei
For latest information on this product please visit http://l.tesa.com/?ip=04952
tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information
and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no
warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore,
the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application.
If you are in any doubt, our technical support staff will be glad to support you.
tesa® 4952
Properties
Temperature resistance short term
Temperature resistance long term
Tack
Ageing resistance (UV)
Humidity resistance
Evaluation across relevant tesa® assortment:
80 °C
80 °C
very good
Resistance to chemicals
Softener resistance
Static shear resistance at 23°C
Static shear resistance at 40°C
good
medium
low
Additional Information
tesa® 4952 has been tested and approved by LGA institute for mirror mounting. Report number IWQ FSG 329 1189.
Page 2 of 2 - as of 16/10/2019 - ei
Peel Adhesion:
- immediately: foam splitting on Steel, Aluminium, ABS, PC, PS, PET, PVC
- after 14 days: foam splitting on Steel, Aluminium, ABS, PC, PS, PET, PVC
很抱歉,暂时无法提供与“04952-00533-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+380.82361
- 10+375.23138
- 20+365.08830
