07078-00011-22
07078-00011-22
    TESA
    TESA - 07078-00011-22 - Foam Tape, Double Sided, Acrylic, Black, 18 m x 19 mm
07078-00011-22 数据手册
plus tesa® ACX Product Information 7078 ACXplus High Resistance 2000µm tesa® ACXplus 7078 is a black acrylic foam tape. It consists of a high-performance acrylic system and due to its unique components it combines a very good temperature resistance with an outstanding cold shock resistance up to -40°C. It is designed for demanding outdoor bonding applications especially in combination with the tesa Adhesion Promoters. The visco-elastic, foamed acrylic core compensates different thermal elongation of bonded parts. Main Application Bonding of panels and reinforcement bars in the following Industries: • • • • Doors & Windows Elevator Production Equipment Transportation Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. Technical Data • Backing material • Colour • Total thickness Adhesion to • Steel (initial) • Aluminium (initial) • Glass (initial) Properties • Temperature resistance short term • Temperature resistance long term • Tack • Ageing resistance (UV) • Humidity resistance foamed acrylic deep black 2000 µm • Type of adhesive • Elongation at break 16.0 N/cm 14.0 N/cm 24.0 N/cm 220 °C 120 °C Evaluation across relevant tesa® assortment:   pure acrylic 1000 % • Steel (after 3 days) • Aluminium (after 3 days) • Glass (after 3 days) • • • • • 40.0 N/cm 32.0 N/cm 40.0 N/cm Resistance to chemicals Softener resistance Static shear resistance at 23°C Static shear resistance at 70°C T-block  very good      good      medium      low Additional Information PV 22 = White PE coated paper liner tesa® ACX plus branded PV 24 = Blue filmic liner For latest information on this product please visit http://l.tesa.com/?ip=07078 Page 1 of 1 – as of 08/09/21 – en-GB tesa® ACX plus 7078 is recognised according to UL Standard 746C. UL File QOQW2.E309290 plus tesa® ACX Product Information 7078 Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=07078 Page 2 of 1 – as of 08/09/21 – en-GB tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
07078-00011-22 价格&库存
很抱歉,暂时无法提供与“07078-00011-22”相匹配的价格&库存,您可以联系我们找货
