productinformation
tesa® 4120 hand
General Purpose Packing Tape for Closing Medium-weight Shipping Boxes
tesa® 4120 is a packaging tape based on a polyvinylchloride-film backing in combination with a natural rubber adhesive. The
natural rubber adhesive system offers very good adhesive properties to various surfaces and can be removed without leaving
behind any residue. tesa® 4120 tape is ideal for manual sealing equipment, though it can also be used with an automatic
sealing machine. A high tack and short dwell time ensure optimal security for your carton just shortly after the tape has been
applied. The tape is convenient to use, and unwinds smoothly, steadily, and quietly. tesa® 4120 tape is easily printable and
available in white, havana, and transparent.
Main Application
tesa® 4120 is used for the manual sealing of medium-range weight cartons
The tape can also be used with automatic sealing equipment
Effortless and low-noise unwinding makes the tape ideal for convenient large-scale use in various industries
A high tack and short dwell time ensure a fast and reliable hold
Technical Data
Backing material
Total thickness
Type of adhesive
PVC film
49 µm
natural rubber
Adhesion to steel
Elongation at break
Tensile strength
Printability
Low noise unwinding
2 N/cm
75 %
43 N/cm
Properties
Manual application
Hand tearability
Evaluation across relevant tesa® assortment:
yes
very good
good
medium
yes
low
Additional Information
Page 1 of 1 - As of 31/10/2019 - en
tesa® 4120 is easily printable. Available colours: white, havana and transparent
For latest information on this product please visit http://l.tesa.com/?ip=04120
tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical
information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered
as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not
limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa®
product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be
glad to support you.
很抱歉,暂时无法提供与“04120-00008-00”相匹配的价格&库存,您可以联系我们找货
