productinformation
tesa® 4970
Double-sided filmic tape with high adhesion
tesa® 4970 is a thick white double-sided self-adhesive tape consisting of a PVC-film backing and a tackified acrylic adhesive.
tesa® 4970 features especially:
Excellent combination of high tack and immediate adhesion
High coating weight for good bonding performance on rough or dusty surfaces
Full suitability for longterm applications
Main Application
Mounting of plastic and wooden trims
Mounting of decorative POS materials and displays
Mounting of signs and scales
Technical Data
Backing material
Color
Total thickness
Type of adhesive
Elongation at break
PVC film
white
225 µm
tackified acrylic
20 %
Tensile strength
Type of liner
Colour of liner
Thickness of liner
Weight of liner
38 N/cm
glassine
brown
71 µm
82 g/m²
Steel (after 14 days)
ABS (after 14 days)
Aluminium (after 14 days)
PC (after 14 days)
PE (after 14 days)
PET (after 14 days)
PP (after 14 days)
PS (after 14 days)
PVC (after 14 days)
Resistance to chemicals
Softener resistance
Static shear resistance at 23°C
Static shear resistance at 40°C
Adhesion to
Steel (initial)
ABS (initial)
Aluminium (initial)
PC (initial)
PE (initial)
PET (initial)
PP (initial)
PS (initial)
PVC (initial)
13.0 N/cm
13.4 N/cm
11.5 N/cm
16.2 N/cm
8.5 N/cm
11.5 N/cm
9.7 N/cm
14.7 N/cm
12.4 N/cm
13.6 N/cm
14.4 N/cm
12.6 N/cm
16.9 N/cm
9.1 N/cm
11.9 N/cm
10.8 N/cm
15.2 N/cm
16.6 N/cm
Temperature resistance short term
Temperature resistance long term
Tack
Ageing resistance (UV)
Humidity resistance
Evaluation across relevant tesa® assortment:
70 °C
60 °C
very good
good
medium
low
For latest information on this product please visit http://l.tesa.com/?ip=04970
tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical
information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered
as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not
limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa®
product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be
glad to support you.
Page 1 of 2 - As of 14/09/2019 - en
Properties
tesa® 4970
Additional Information
Page 2 of 2 - As of 14/09/2019 - en
Liner variants:
PV0: brown glassine paper (69μm; 80g/m²)
PV2: brown glassine paper (78μm; 90g/m²)
很抱歉,暂时无法提供与“04970-00151-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+565.73292
- 5+549.16734
- 25+451.94192
