06032-00000-00
06032-00000-00
    TESA
06032-00000-00 数据手册
tesa® 6032 Product Information Industrial hand dispenser "Strap-it" The tesa® 6032 hand dispenser is a simple device that takes tesa® filament and strapping tapes up to 25 mm width. The tesa® 6032 hand dispenser is used for sealing shipping cartons with L-seals, bundling rod and ring-shaped products, and for securing pallets. The special blade is designed to cut tesa® filament reinforced packaging tapes. Main Application When using tesa® strapping tapes for securing pallets, press down the brake plate to ensure the tape is unwound at the required tension. Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. Technical Data • Core diameter • Type of tape • Application purpose • Length • Mode of drive 3 inch single-sided transport securing 220 mm manual • • • • Weight Max. roll diameter Type of applicator Max. roll width 335 g 150 mm hand 25 mm Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=06032 Page 1 of 1 – as of 10/09/21 – en-US tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
06032-00000-00 价格&库存
很抱歉,暂时无法提供与“06032-00000-00”相匹配的价格&库存,您可以联系我们找货
