04965-00180-00
04965-00180-00
    TESA
04965-00180-00 数据手册
tesa® 4965 product information Double-coated tape with high shear and temperature resistance tesa® 4965 is a transparent double-sided self-adhesive tape consisting of a PET backing and a modified acrylic adhesive. tesa® 4965 features: • Reliable bond even to LSE substrates • Immediate usability after assembly • Suitability for most demanding applications such as heavy stress, high temperatures or critical substrates Main Application • • • • Mounting of ABS plastic parts in the car industry Self-adhesive mounting of rubber/EPDM profiles Mounting of decorative profiles and mouldings in the furniture industry Mounting of battery packs, lenses and touch-screens in electronic devices Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. PET film transparent 205 µm Adhesion to • Steel (initial) • ABS (initial) • Aluminium (initial) • PC (initial) • PE (initial) • PET (initial) • PP (initial) • PS (initial) • PVC (initial) Properties • Temperature resistance short term • Temperature resistance long term • Tack • Ageing resistance (UV) • Humidity resistance • Type of adhesive • Elongation at break • Tensile strength 11.5 N/cm 10.3 N/cm 9.2 N/cm 12.6 N/cm 5.8 N/cm 9.2 N/cm 6.8 N/cm 10.6 N/cm 8.7 N/cm 200 °C 100 °C Evaluation across relevant tesa® assortment:   For latest information on this product please visit http://l.tesa.com/?ip=04965 tackified acrylic 50 % 20 N/cm • • • • • • • • • Steel (after 14 days) ABS (after 14 days) Aluminium (after 14 days) PC (after 14 days) PE (after 14 days) PET (after 14 days) PP (after 14 days) PS (after 14 days) PVC (after 14 days) • • • • Resistance to chemicals Softener resistance Static shear resistance at 23°C Static shear resistance at 40°C  very good      good     11.8 N/cm 12.0 N/cm 10.6 N/cm 14.0 N/cm 6.9 N/cm 9.5 N/cm 7.9 N/cm 12.0 N/cm 13.0 N/cm  medium      low Page 1 of 2 – as of 29/05/20 – en-GB Technical Data • Backing material • Color • Total thickness tesa® 4965 product information Additional Information Liner variants: PV0 red MOPP-film (80µm; 72g/m²) PV1 brown glassine paper (71µm; 82g/m²) PV4 white with blue tesa® logo PE-coated paper (118µm; 120g/m²) PV7 transparent PET-film (50µm; 72g/m²) PV11 white PET-film (50µm; 72g/m²) PV36 double-liner: red MOPP-film (80µm; 72g/m²) and brown glassine paper (71µm; 82g/m²) Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=04965 Page 2 of 2 – as of 29/05/20 – en-GB tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
04965-00180-00 价格&库存
很抱歉,暂时无法提供与“04965-00180-00”相匹配的价格&库存,您可以联系我们找货
