62932 25MM
62932 25MM
    TESA
    TESA - 62932 25MM - TAPE, DBLE SIDED, FOAM, 62932, 25MMX50MM
62932 25MM 数据手册
PRODUCT INFORMATION tesa 62932 Constructive d/s mounting foam tape Product Description/ Application: tesa 62932 foam tape offers an excellent long term adhesive performance for demanding constructive applications at a small design gap. Due to its state-of-the-art product design tesa 62932 offers benefits for various industrial applications: • Thin foam backing allows to implement a small design gap • High immediate bonding strength for fast and reliable assembly even at low pressure • Highly conformable foam backing compensates for design tolerances or uneven surfaces Product Design: Liner: • High ultimate adhesive strength for secure bonding performance • High foam elasticity to level-out different thermal expansion of bonded parts • Very good humidity resistance • Good dampening properties offer shock absorption during transport and in daily use Typical application examples • Decorative aluminium cover screens on brown goods • Door handles in kitchen furniture • Moulded decorative profiles for refrigerators or freezers • Glass and mirror panels Backing Adhesive Thickness* Colour PE foam Tackified acrylic 500 µm Black / white Colour Type Thickness* Weight* Brown Glassine paper 71 µm 80 g/m² Blue PE 100 µm 94 g/m² * Mean values / parameter of the specification Dimensions: Pancake rolls, log rolls, cross wound spools tesa AG P.O. Box 57 02 62 D- 22771 Hamburg Telephone +49-40 49092618 Telefax +49-40 49094506 A Beiersdorf Company tesa self-adhesive tapes are used successfully in many sectors to solve a variety of problems. Our publications contain n umerous examples of such uses, intended to help towards a solutio n of your particular problems. Each tesa product has been developed for a particular range of applications. Nevertheless, experience has shown that even for one and the same obje ctive, the exact requirements may differ from case to case. We, therefore, rec ommend that you carry out your own tests in each case, to confirm that the tesa self-adhesive tape which you envisage using is appropriate for your particular application. The Advisory Section of our Technical Service Department will be happy to assist. All information and recommendations are given by us in good faith, on the basis of practical experience, but without warranty. PRODUCT INFORMATION Technical Data tesa 62932 Mean values / parameters of the specification Peel adhesion on different surfaces: immediately [N/cm] after 14 days [N/cm] Steel Aluminium 13,0 13,0 = 17,0* = 17,0* ABS 14, 0 = 17,0* PC 9, 0 = 17,0* PS 10,5 = 17,0* PET 12,5 = 17,0* PVC 14,5 = 17,0* PP 1,8 3,3 PE 1,7 3,0 * foam splitting during measurement Temperature resistance Short Term Long Term 80 °C 80 °C Mechanical properties ≥ 12 N/15mm ≥ 270 % Tensile strength Elongation Results of laboratory evaluation Static shear resistance (1000 g / 13 mm x 20 mm) 23°C 40°C + + Tack (Rolling Ball) 0 Softener resistance 0 Humidity resistance ++ Solvent resistance + Ageing resistance (UV) + Evaluation: very good ( ++) good ( + ) medium ( O ) low ( - ) 7100-05/06 tesa AG P.O. Box 57 02 62 D- 22771 Hamburg Telephone +49-40 49092618 Telefax +49-40 49094506 A Beiersdorf Company tesa self-adhesive tapes are used successfully in many sectors to solve a variety of problems. Our publications contain n umerous examples of such uses, intended to help towards a solutio n of your particular problems. Each tesa product has been developed for a particular range of applications. Nevertheless, experience has shown that even for one and the same obje ctive, the exact requirements may differ from case to case. We, therefore, rec ommend that you carry out your own tests in each case, to confirm that the tesa self-adhesive tape which you envisage using is appropriate for your particular application. The Advisory Section of our Technical Service Department will be happy to assist. All information and recommendations are given by us in good faith, on the basis of practical experience, but without warranty.
62932 25MM 价格&库存
很抱歉,暂时无法提供与“62932 25MM”相匹配的价格&库存,您可以联系我们找货
