60760-00098-15
60760-00098-15
    TESA
    TESA - 60760-00098-15 - Tape, Floor Marking, PVC (Polyvinyl Chloride), Blue, 33 m x 50 mm
60760-00098-15 数据手册
tesa® Professional 60760 Floor Marking Tape Product Information Floor marking tape / hazard tape tesa® 65537 is a hazard tape intended for temporary use. The tower includes 6 roles. While the substrate material is soft PVC, the modified adhesive is made of natural rubber for good adhesive strength and reliable adhesion to the surface underneath. The abrasion-proof hazard tape, which can be torn by hand, is also suited to rough surfaces and is a valuable aid when marking hazards on building sites or in workshops. Features • Temporary marking applications • Identify and mark mobile and stationary objects • Adhesion on many different surfaces Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. soft PVC litho-red 150 µm Adhesion to • Steel (initial) • Type of adhesive • Elongation at break • Tensile strength natural rubber 220 % 33 N/cm 2.0 N/cm Properties • Straight tear edges • Suitable for sensitive surfaces • Suitable for rough surfaces • Tack • Ageing resistance (UV) Evaluation across relevant tesa® assortment:   For latest information on this product please visit http://l.tesa.com/?ip=60760 • • • • Humidity resistance UV-resistance Water resistant Static shear resistance at 23°C  very good      good      medium      low Page 1 of 1 – as of 08/09/21 – en-GB Technical Data • Backing material • Colour • Total thickness tesa® Professional 60760 Floor Marking Tape Product Information Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=60760 Page 2 of 1 – as of 08/09/21 – en-GB tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
60760-00098-15 价格&库存
很抱歉,暂时无法提供与“60760-00098-15”相匹配的价格&库存,您可以联系我们找货
