04124-00015-00
04124-00015-00
    TESA
04124-00015-00 数据手册
productinformation tesa® 4124 Premium general purpose carton sealing tape tesa® 4124 is a premium packaging tape based on a PVC-film backing and a natural rubber adhesive. It shows excellent performance on all kind of cardboards and secures a safe closure of medium and also heavy-weight cartons. tesa® 4124 unwinds smoothly and without noise which makes 4124 ideal for use in hand dispensers and automatic sealing equipment. The process of cardboard waste recycling will be not disrupted as confirmed by leading recycling companies and paper mills. Main Application tesa® 4124 is used for manual and automatic sealing of cartons of medium to heavy-range weight. Technical Data ▪ ▪ ▪ Backing material Total thickness Type of adhesive PVC film 65 µm natural rubber ▪ ▪ ▪ Adhesion to steel Elongation at break Tensile strength ▪ ▪ Printability Low noise unwinding 3.2 N/cm 60 % 60 N/cm Properties ▪ ▪ Automatic application Manual application Evaluation across relevant tesa® assortment: yes yes very good good medium yes low Additional Information Page 1 of 1 - as of 31/10/2019 - ei tesa® 4124 is easy printable. Available colours: white, havana and transparent For latest information on this product please visit http://l.tesa.com/?ip=04124 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
04124-00015-00 价格&库存
很抱歉,暂时无法提供与“04124-00015-00”相匹配的价格&库存,您可以联系我们找货
  • 1+66.10704
  • 10+64.73242
  • 20+63.19117
库存:106
