04843-00000-16
04843-00000-16
    TESA
    TESA - 04843-00000-16 - Protective Tape, PVC (Polyvinyl Chloride) Film, Orange, 33 m x 50 mm
04843-00000-16 数据手册
tesa® Professional 4843 Product Information Premium plastering protection tape to protect sensitive profiles and facings The tesa® plastering protection tape won’t let you down at any time of year, because the sturdy tape will stick reliably even when it’s cold. This means it provides optimum protection for painting, stucco and plastering work. It comprises a supple, tear-resistant, soft PVC film and is coated with a special aging-resistant adhesive compound. The plastering masking tape protects the surfaces of sensitive profiles, frames and facing from soiling or damage through plastering material or tools. The tape is insensitive to humidity, weak acid and alkaline solutions as well as to many chemicals. Main Application • • • • • Outdoor applications Good protection of smooth and slightly rough surfaces For applications that require high adhesion power (e.g. plastering, painting, gypsum, masonry and stucco work) Also suitable for the sealing of bags, heavy duty wrapping and other DIY applications For temperatures above 0°C Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. PVC film orange 122 µm natural rubber Adhesion to • steel Properties • Hand tearability • Easy to remove • Easy to write on • Suitable for rough surfaces • Paint anchorage • Sharp color edge • Abrasion resistance • Elongation at break • Tensile strength • Temperature resistance short term • UV-resistance 200 % 23 N/cm 60 °C 2 weeks 1.2 N/cm yes no Evaluation across relevant tesa® assortment:   For latest information on this product please visit http://l.tesa.com/?ip=04843 • • • • • • • Ageing resistance (UV) Humidity resistance UV-resistance Water resistance Fluorescent Conformability Fogging  very good      good     no  medium      low Page 1 of 2 – as of 22/10/21 – en-US Technical Data • Backing material • Color • Total thickness • Type of adhesive tesa® Professional 4843 Product Information Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=04843 Page 2 of 2 – as of 22/10/21 – en-US tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
04843-00000-16 价格&库存
很抱歉,暂时无法提供与“04843-00000-16”相匹配的价格&库存,您可以联系我们找货
    • 1+855.16347
    库存:6
