62932 9MM
62932 9MM
    TESA
    TESA  62932 9MM  TAPE, DBLE SIDED, FOAM, 62932, 9MM
62932 9MM 数据手册
productinformation tesa® 62932 500 µm double sided PE foam tape tesa® 62932 is a double sided PE foam tape for constructive mounting applications. It consists of a conformable PE foam backing and a tackified acrylic adhesive. Product benefits: ▪ ▪ ▪ ▪ ▪ ▪ Thin foam backing for a small design gap Versatile adhesive for high immediate adhesion on numerous substrates High ultimate adhesion level for a secure bonding performance Fully outdoor suitable: UV, water and ageing resistant High immediate bonding strength even at low bonding pressure Very good cold shock absorbtion Main Application ▪ ▪ ▪ ▪ Decorative aluminium cover screens on brown goods Doorhandles in kitchen furniture Moulded decorative profiles for refrigerators or freezers Glass and mirror panels Technical Data ▪ ▪ ▪ Backing material Color Total thickness PE foam black/white 500 µm ▪ ▪ ▪ Type of adhesive Elongation at break Tensile strength ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ Steel (after 14 days) ABS (after 14 days) Aluminium (after 14 days) PC (after 14 days) PE (after 14 days) PET (after 14 days) PP (after 14 days) PS (after 14 days) PVC (after 14 days) tackified acrylic 270 % 8 N/cm Adhesion to Steel (initial) ABS (initial) Aluminium (initial) PC (initial) PE (initial) PET (initial) PP (initial) PS (initial) PVC (initial) 13.0 N/cm 14.0 N/cm 13.0 N/cm 9.0 N/cm 1.7 N/cm 12.5 N/cm 1.8 N/cm 10.5 N/cm 14.5 N/cm 17.0 N/cm 17.0 N/cm 17.0 N/cm 17.0 N/cm 3.0 N/cm 17.0 N/cm 3.3 N/cm 17.0 N/cm 17.0 N/cm Page 1 of 2 - As of 30/10/2019 - en ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ For latest information on this product please visit http://l.tesa.com/?ip=62932 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you. tesa® 62932 500 µm double sided PE foam tape Properties ▪ ▪ ▪ ▪ ▪ Temperature resistance short term Temperature resistance long term Tack Ageing resistance (UV) Humidity resistance Evaluation across relevant tesa® assortment: 80 °C 80 °C ▪ ▪ ▪ ▪ very good Resistance to chemicals Softener resistance Static shear resistance at 23°C Static shear resistance at 40°C good medium low Additional Information Liner variants: ▪ ▪ ▪ ▪ PV0 brown glassine paper (71 µm) PV10 redtransparent PP film(120 µm) PV14 PE coated paper (122 µm) PV15 blue PE film (100 µm) Peel Adhesion: after 14 days: foam splitting on Steel, Aluminium, ABS, PC, PS, PET, PVC Page 2 of 2 - As of 30/10/2019 - en ▪ For latest information on this product please visit http://l.tesa.com/?ip=62932 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
62932 9MM 价格&库存
很抱歉,暂时无法提供与“62932 9MM”相匹配的价格&库存,您可以联系我们找货
