04657-00112-00
04657-00112-00
    TESA
04657-00112-00 数据手册
productinformation tesa® 4657 Temperature resistant acrylic coated cloth tape tesa® 4657 is a high grade acrylic coated cloth tape. It is based on a 145 mesh woven cotton fabric and a thermosetting natural rubber adhesive. tesa® 4657 is a very resilient cloth tape often used for permanent hole covering in automotive applications and masking during industrial painting processes. Features: ▪ ▪ ▪ ▪ ▪ ▪ removable without residues even after high temperature exposure very ageing-resistant (allowing for permanent applications) high resistance to paint solvents excellent tape for die-cuts, available as log roll with liner as tesa® 4657 PV9 also available as low unwinding version tesa® 4657 PV 1 available in 2 colors: black, grey Main Application ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ Heat resistant masking during the production of vehicles and machines Window flange masking Even repeated oven drying possible Permanent interior and exterior hole covering Covering of screw tap holes and drainage boreholes Partial masking during treatment with impregnating agents Fastening of flat cables e.g. on roof linings, door panels, mirrors Masking during electrostatic powder coating Technical Data ▪ ▪ ▪ Backing material Total thickness Type of adhesive ▪ Adhesion to steel acrylic-coated cloth 290 µm thermosetting natural rubber 4.6 N/cm ▪ ▪ ▪ ▪ Elongation at break Tensile strength Temperature resistance (30 min) Mesh ▪ ▪ ▪ ▪ Suitable for die cutting Certified according to Abrasion resistance Water resistance 7.5 % 105 N/cm 180 °C 145 count per square inch Properties Hand tearability Straight tear edges Easy to remove Easy to write on Evaluation across relevant tesa® assortment: yes yes very good good medium yes all major OEMs low For latest information on this product please visit http://l.tesa.com/?ip=04657 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you. Page 1 of 1 - as of 17/10/2019 - ei ▪ ▪ ▪ ▪
04657-00112-00 价格&库存
很抱歉,暂时无法提供与“04657-00112-00”相匹配的价格&库存,您可以联系我们找货
