51571-00000-00
51571-00000-00
    TESA
51571-00000-00 数据手册
productinformation tesa® 51571 Double-sided non-woven tape tesa® 51571 is a double-sided tape with a non-woven backing. It is used for permanent mounting of metal and plastic materials, e.g. aluminium, polystyrene, polypropylene, ABS. The very thick layer of adhesive bonds extremely well on uneven surfaces and has a very high initial bond. Main Application tesa® 51571 is used for applications like Mounting of evaporator plates in the production of refrigerators Technical Data ▪ ▪ ▪ ▪ ▪ Backing material Color Total thickness Type of adhesive Elongation at break non-woven translucent 160 µm synthetic rubber 2% ▪ ▪ ▪ ▪ ▪ Tensile strength Type of liner Colour of liner Thickness of liner Weight of liner 9 N/cm glassine brown 70 µm 78 g/m² ▪ ▪ ▪ ▪ ▪ ▪ ▪ PP (initial) PS (initial) PVC (initial) Steel (after 14 days) PE (after 14 days) PP (after 14 days) PVC (after 14 days) ▪ ▪ ▪ ▪ Static shear resistance at 23°C Static shear resistance at 40°C Static shear resistance at 70°C Fogging Adhesion to ▪ ▪ ▪ ▪ ▪ ▪ ▪ Steel (initial) Steel (covered side, initial) ABS (initial) Aluminium (initial) PC (initial) PE (initial) PET (initial) 12.5 N/cm 12.5 N/cm 11.8 N/cm 13.0 N/cm 13.4 N/cm 8.0 N/cm 10.6 N/cm 9.0 N/cm 12.4 N/cm 12.0 N/cm 13.0 N/cm 8.5 N/cm 9.0 N/cm 13.0 N/cm Properties ▪ ▪ ▪ ▪ ▪ Temperature resistance short term Temperature resistance long term Tack Ageing resistance (UV) Humidity resistance very good good medium low Page 1 of 1 - As of 25/09/2019 - en Evaluation across relevant tesa® assortment: 80 °C 40 °C For latest information on this product please visit http://l.tesa.com/?ip=51571 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
51571-00000-00 价格&库存
很抱歉,暂时无法提供与“51571-00000-00”相匹配的价格&库存,您可以联系我们找货
  • 1+42.16563
  • 10+40.90556
  • 20+39.52052
库存:282
