productinformation
tesa® 51608
PET fleece tape for flexibility and noise damping
tesa® 51608 is the universal tape for wire harness bundling in the passenger compartment. It combines important features
as noise dampening, abrasion resistance, and bundling strength while keeping harnesses flexible supporting an easy harness
assembly process at the OEM. tesa® 51608 a PET fleece wire harness tape with a rubber based adhesive that is optimized for
manual application.
Major Features:
Noise dampening
Abrasion resistant
Flexible and smooth
Tear resistant
Stable unwind force
Age-resistant
Strong adhesion
Hand-tearable
Color: Black
Main Application
tesa® 51608 is designed for the passenger compartment, providing flexibility and noise damping.
Technical Data
Backing material
Total thickness
Type of adhesive
Adhesion to steel
Elongation at break
Tensile strength
Temperature resistance min.
PET fleece
280 µm
rubber based
3 N/cm
20 %
40 N/cm
-40 °C
Temperature resistance (3000h)
Abrasion resistance (10mm
mandrel)
Abrasion resistance (5mm
mandrel)
Flame resistance as composite
Unwind force (roll width ≤ 9mm)
Unwind force (roll width > 9mm)
Noise damping (decibel)
105 °C
Class B (acc. to
LV312)
Class A (acc. to
LV312)
Class B (acc. to
LV312)
4.6 N/roll (30 m/min)
9 N/roll (30 m/min)
Class C (acc. to
LV312)
Standard widths: 9, 19, 25, 32 mm
Standard lengths: 25 m
Most combinations of width and length are possible
Further dimensions are available upon request
Standard core diameter: 38 mm
For latest information on this product please visit http://l.tesa.com/?ip=51608
tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical
information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered
as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not
limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa®
product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be
glad to support you.
Page 1 of 1 - As of 04/09/2019 - en
Additional Information
很抱歉,暂时无法提供与“51608-00006-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+63.23282
- 10+62.31640
- 20+61.29585
- 国内价格 香港价格
- 1+25.635751+3.28830
- 10+22.2881310+2.85890
- 20+19.1167020+2.45210
- 60+17.0024160+2.18090
- 120+14.88812120+1.90970
