tesa® 4965
product information
Double-coated tape with high shear and temperature resistance
tesa® 4965 is a transparent double-sided self-adhesive tape consisting of a PET backing and a modified acrylic adhesive.
tesa® 4965 features:
• Reliable bond even to LSE substrates
• Immediate usability after assembly
• Suitability for most demanding applications such as heavy stress, high temperatures or critical substrates
Main Application
Mounting of ABS plastic parts in the car industry
Self-adhesive mounting of rubber/EPDM profiles
Mounting of decorative profiles and mouldings in the furniture industry
Mounting of battery packs, lenses and touch-screens in electronic devices
Technical Information (average values)
The values in this section should be considered representative or typical only and should not be used for specification
purposes.
PET film
transparent
205 µm
Adhesion to
• Steel (initial)
• ABS (initial)
• Aluminium (initial)
• PC (initial)
• PE (initial)
• PET (initial)
• PP (initial)
• PS (initial)
• PVC (initial)
Properties
• Temperature resistance short term
• Temperature resistance long term
• Tack
• Ageing resistance (UV)
• Humidity resistance
• Type of adhesive
• Elongation at break
• Tensile strength
11.5 N/cm
10.3 N/cm
9.2 N/cm
12.6 N/cm
5.8 N/cm
9.2 N/cm
6.8 N/cm
10.6 N/cm
8.7 N/cm
200 °C
100 °C
Evaluation across relevant tesa® assortment:
For latest information on this product please visit
http://l.tesa.com/?ip=04965
tackified acrylic
50 %
20 N/cm
Steel (after 14 days)
ABS (after 14 days)
Aluminium (after 14 days)
PC (after 14 days)
PE (after 14 days)
PET (after 14 days)
PP (after 14 days)
PS (after 14 days)
PVC (after 14 days)
Resistance to chemicals
Softener resistance
Static shear resistance at 23°C
Static shear resistance at 40°C
very good
good
11.8 N/cm
12.0 N/cm
10.6 N/cm
14.0 N/cm
6.9 N/cm
9.5 N/cm
7.9 N/cm
12.0 N/cm
13.0 N/cm
medium low
Page 1 of 2 – as of 29/05/20 – en-GB
Technical Data
• Backing material
• Color
• Total thickness
tesa® 4965
product information
Additional Information
Liner variants:
PV0 red MOPP-film (80µm; 72g/m²)
PV1 brown glassine paper (71µm; 82g/m²)
PV4 white with blue tesa® logo PE-coated paper (118µm; 120g/m²)
PV7 transparent PET-film (50µm; 72g/m²)
PV11 white PET-film (50µm; 72g/m²)
PV36 double-liner: red MOPP-film (80µm; 72g/m²) and brown glassine paper (71µm; 82g/m²)
Disclaimer
Page 2 of 2 – as of 29/05/20 – en-GB
tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict
controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical
experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied
warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether
the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our
technical support staff will be glad to support you.
很抱歉,暂时无法提供与“04965-00179-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+287.543241+36.88320
- 6+273.007506+35.01870
- 12+251.2479512+32.22760
