60951-00000-00
60951-00000-00
    TESA
60951-00000-00 数据手册
productinformation tesa® 60951 Anti Slip safety solution The application area for tesa® Anti Slip Professional range is everywhere safe footing is required. Anti Slip yellow & black is the ideal protection to prevent from skidding and therefore helps to avoid accidents in the job related. Very good adhesion of the product is suitable for demanding surfaces such as factory floors, industry areas etc. The strong and durable adhesive coating secures a high Anti Slip effect of up to 1- 2 years in normal use areas. The Anti Slip tapes are hand tearable and no shrinkage occurs after application. Main Application Everywhere safe footing is required. Technical Data ▪ ▪ ▪ Backing material Total thickness Type of adhesive PVC film 800 µm acrylic ▪ ▪ ▪ Adhesion to steel Elongation at break Temperature resistance ▪ ▪ Resistance to chemicals Salt water resistant 5.8 N/cm 25 % -5 to +50 °C Properties ▪ ▪ Hand tearability Suitable for die cutting very good good medium low Page 1 of 1 - as of 31/10/2019 - ei Evaluation across relevant tesa® assortment: yes For latest information on this product please visit http://l.tesa.com/?ip=60951 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
60951-00000-00 价格&库存
很抱歉,暂时无法提供与“60951-00000-00”相匹配的价格&库存,您可以联系我们找货
