62936-00007-00
62936-00007-00
    TESA
62936-00007-00 数据手册
productinformation tesa® 62936 Double-sided PE foam mounting tape tesa® 62936 is a double-sided PE-foam tape for constructive mounting applications. It consists of a highly conformable PEfoam backing with a tackified acrylic adhesive. Product benefits: ▪ ▪ ▪ ▪ ▪ ▪ Versatile adhesive for high immediate adhesion on numerous substrates High ultimate adhesion level for a secure bonding performance UV, water and ageing resistant Compensates for differing thermal expansion of dissimilar materials High immediate bonding strength even at low bonding pressure Very good cold shock absorbtion Main Application ▪ ▪ ▪ ▪ Interior wall cladding panels Bumper rails on commercial freezers Injection moulded plastic parts Mirrors and coloured glass panels Technical Data ▪ ▪ ▪ Backing material Color Total thickness PE foam black/white 1600 µm ▪ ▪ ▪ Type of adhesive Elongation at break Tensile strength ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ Steel (after 14 days) ABS (after 14 days) Aluminium (after 14 days) PC (after 14 days) PE (after 14 days) PET (after 14 days) PP (after 14 days) PS (after 14 days) PVC (after 14 days) tackified acrylic 175 % 9 N/cm Adhesion to Steel (initial) ABS (initial) Aluminium (initial) PC (initial) PE (initial) PET (initial) PP (initial) PS (initial) PVC (initial) 16.0 N/cm 17.0 N/cm 15.0 N/cm 19.0 N/cm 2.0 N/cm 15.0 N/cm 3.0 N/cm 19.0 N/cm 19.0 N/cm 19.0 N/cm 19.0 N/cm 19.0 N/cm 19.0 N/cm 3.0 N/cm 19.0 N/cm 7.0 N/cm 19.0 N/cm 19.0 N/cm Page 1 of 2 - as of 05/09/2019 - ei ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ For latest information on this product please visit http://l.tesa.com/?ip=62936 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you. tesa® 62936 Double-sided PE foam mounting tape Properties ▪ ▪ ▪ ▪ ▪ Temperature resistance short term Temperature resistance long term Tack Ageing resistance (UV) Humidity resistance Evaluation across relevant tesa® assortment: 80 °C 80 °C ▪ ▪ ▪ ▪ very good Resistance to chemicals Softener resistance Static shear resistance at 23°C Static shear resistance at 40°C good medium low Additional Information Liner variants: PV0 brown glassine paper (71 µm) PV14 white PE-coated paper (120 µm) PV10 red filmic liner (120 µm) tesa® 62936 has been tested by TÜV Rheinland, Germany. The test confirms the longterm adhesion performance after IEC 61215 / 61646 climate tests and a 85°C temperature resistance. (TÜV report number 21209595). Page 2 of 2 - as of 05/09/2019 - ei Peel Adhesion: - immediate: foam splitting on PC, PS, PVC - after 14 days: foam splitting on Steel, Aluminium, ABS, PC, PS, PET, PVC For latest information on this product please visit http://l.tesa.com/?ip=62936 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
62936-00007-00 价格&库存
很抱歉,暂时无法提供与“62936-00007-00”相匹配的价格&库存,您可以联系我们找货
  • 1+180.685281+23.47010
  • 8+169.463138+22.01240
  • 16+158.1539916+20.54340
  • 1+266.76085
  • 10+261.13738
  • 20+257.27385
库存:35
