04965-00176-00
04965-00176-00
    TESA
04965-00176-00 数据手册
productinformation tesa® 4965 205µm double sided transparent filmic tape tesa® 4965 is a transparent, double-sided self-adhesive tape consisting of a PET backing and a tackyfied acrylic adhesive. tesa® 4965 features especially: ▪ ▪ ▪ Reliable bond even on hard to stick surfaces Immediate usability right after assembly Suitability for critical demands such as heavy stress and high temperatures Main Application Based on tesa® 4965's patented and protected techology, its unique performance is demonstrated through outstanding qualities such as versatility, durability and safety. Across all industries tesa® 4965 is used to improve processes and applications. Key applications include: ▪ ▪ ▪ ▪ ABS plastics parts mounting for the car industry Self-adhesive mounting for rubber/EPDM profiles Decorative moulding and profile mounting in the furniture industry Battery pack, lens and touch-screen mounting for electronic devices 4965 is recognized according to UL standard 969. UL file: MH 18055 Certificate available according to DIN EN 45545-2 fulfilling 2R1+HL3 Technical Data ▪ ▪ ▪ Backing material Color Total thickness PET film transparent 205 µm ▪ ▪ ▪ Type of adhesive Elongation at break Tensile strength ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ Steel (after 14 days) ABS (after 14 days) Aluminium (after 14 days) PC (after 14 days) PE (after 14 days) PET (after 14 days) PP (after 14 days) PS (after 14 days) PVC (after 14 days) tackified acrylic 50 % 20 N/cm ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ Steel (initial) ABS (initial) Aluminium (initial) PC (initial) PE (initial) PET (initial) PP (initial) PS (initial) PVC (initial) 11.5 N/cm 10.3 N/cm 9.2 N/cm 12.6 N/cm 5.8 N/cm 9.2 N/cm 6.8 N/cm 10.6 N/cm 8.7 N/cm For latest information on this product please visit http://l.tesa.com/?ip=04965 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you. 11.8 N/cm 12.0 N/cm 10.6 N/cm 14.0 N/cm 6.9 N/cm 9.5 N/cm 7.9 N/cm 12.0 N/cm 13.0 N/cm Page 1 of 2 - As of 31/10/2019 - en Adhesion to tesa® 4965 205µm double sided transparent filmic tape Properties ▪ ▪ ▪ ▪ ▪ Temperature resistance short term Temperature resistance long term Tack Ageing resistance (UV) Humidity resistance 200 °C 100 °C Evaluation across relevant tesa® assortment: ▪ ▪ ▪ ▪ very good Resistance to chemicals Softener resistance Static shear resistance at 23°C Static shear resistance at 40°C good medium low Additional Information Liner variants: PV0: red MOPP-film (80µm; 72g/m²) PV1: brown glassine paper (69µm; 80g/m²) PV2: brown glassine paper (78μm; 90g/m²) PV4: branded white paper liner (104μm; 120g/m²) PV8: white MOPP friction liner (80μm; 72g/m²) PV20: branded brown paper liner (69μm; 80g/m²) This product information applies to PV1 Page 2 of 2 - As of 31/10/2019 - en According to VDA278 analysis, tesa 4965 does not contain any single substances restricted by the drafted GB regulations (China) as well as the indoor concentration guideline by Health, Labour and Welfare Ministry (Japan). For latest information on this product please visit http://l.tesa.com/?ip=04965 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
04965-00176-00 价格&库存
很抱歉,暂时无法提供与“04965-00176-00”相匹配的价格&库存,您可以联系我们找货
    • 1+171.84914
    库存:116
