06400-00001-02
06400-00001-02
    TESA
    TESA - 06400-00001-02 - Tape Dispenser, Single Side, 220 mm Length, 6400 Series
06400-00001-02 数据手册
tesa® 6400 product information Dispenser COMFORT for packaging tapes The tesa® 6400 hand dispenser is a robust industrial device that applies tesa® tapes up to 50 mm width. Its system of a covered blade provides a special injury-protection (blade-protection). The tape is cut by pressing the flap on the tape while the serrated cutting blade will “pop out” to cut the tape. The continuously adjustable tension control allows correct dispensing even of easy unwinding tesa® tape. tesa® 6400 has a soft gummed handle which ensures a comfortable and secure grip. Main Application Place the tesa 6400 dispenser on the carton and pull it towards yourself. The tape is unwound and pressed down by the contact roller. To cut the tape, press the plastic flap on the carton and continue moving the dispenser. Threading: The tesa roll is put on the tape wheel such that the adhesive side of the tape faces the handle. Pull the end of the tape between the tape contact roller and the metal loading gate until the tape is free of wrinkles. Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. Technical Data • Core diameter • Type of tape • Application purpose • Length • • 3 inch single-sided packaging 220 mm 60 mm 220 mm • • • • • Mode of drive Weight Max. roll diameter Type of applicator Max. roll width manual 500 g 140 mm hand 50 mm For latest information on this product please visit http://l.tesa.com/?ip=06400 Page 1 of 1 – as of 02/06/20 – en-US Additional Information • Very robust due to stable metal frame • Retractable blade for safe usage (injury protection) • Soft gummed handle for secure and comfortable grip • Adjustable tension control • Rubber roller for easy application • Spare part service • Empty tesa® 6400 product information Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=06400 Page 2 of 1 – as of 02/06/20 – en-US tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
06400-00001-02 价格&库存
很抱歉,暂时无法提供与“06400-00001-02”相匹配的价格&库存,您可以联系我们找货
