53988 GREY 25M X 19MM
    TESA
    TESA - 53988 GREY 25M X 19MM - TAPE, PVC, 25M X 19MM, GREY
53988 GREY 25M X 19MM 数据手册
productinformation tesa® Professional 53988 tesaflex 53988 Soft PVC Insulation Tape, certified according to IEC 60454-3-1 / 5 Norm The electric insulation tape tesaflex 53988 is a reliable helper for electricians, mechanics and other handymen. It is characterized by its relatively thick base material, a high degree of flexibility and a very good adhesive performance (even on steel and at low temperatures). The PVC insulation tape is not only suited for insulating and marking wires but also for repairs and bundling. Since it is available in many colors – red, blue, brown, black, white, gray, green, yellow and yellow-green -, it can also be used as a marking adhesive tape. tesaflex 53988 is certified according to all relevant standards and can be used easily. Main Application ▪ ▪ ▪ ▪ ▪ ▪ Ideally suited for electrical applications, e.g. insulating or marking wires Certified according to IEC 60454-3-1 (VDE, IMQ, SEMKO), VOC-certified, RoHS 2.0 and REACH conform Thick backing material (150 μm) High dielectric breakdown voltage (7.000 V) Heat-resistant up to +90° C Available in many different colors and dimensions Technical Data Backing material Total thickness Type of adhesive Adhesion to steel soft PVC 150 µm natural rubber 2.2 N/cm ▪ ▪ ▪ ▪ Elongation at break Tensile strength Temperature resistance Dielectric breakdown voltage 240 % 25 N/cm 90 °C 7000 volt Page 1 of 1 - As of 27/09/2019 - en ▪ ▪ ▪ ▪ For latest information on this product please visit http://l.tesa.com/?ip=53988 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
53988 GREY 25M X 19MM 价格&库存
很抱歉,暂时无法提供与“53988 GREY 25M X 19MM”相匹配的价格&库存,您可以联系我们找货
