53948-00042-07
53948-00042-07
    TESA
53948-00042-07 数据手册
tesaflex®�53948 PVC�Electrical�Insulation�Tape�IMQ�&�SEMKO�&�IEC PRODUCT�INFORMATION Product�Description tesa®�53948�IMQ/SEMKO/IEC�is�a�specially�formulated�self�extinguishing�plasticised�PVC�tape�with�good�film�flexibility�and�adhesion�for low�temperature�application. Using�plasticisers�that�are�unaffected�by�most�wiring�systems�plus�a�modified�rubber�adhesive�system�make�tesa®�53948�IMQ/SEMKO/ IEC�ideal�in�electrical�insulation�application. Main�Application tesa®�53948�is�suitable�for�wire�and�cable�insulation,�bundling,�marking,�reinforcing,�sealing�and�protection�applications. Technical�Data Backing�material Type�of�adhesive Total�thickness Adhesion�to�steel Soft�PVC natural�rubber 120�µm 2�N/cm Elongation�at�break Tensile�strength Dielectric�breakdown�voltage 170�% 23�N/cm 5000�volt Properties Certified�according�to IMQ,�SEMKO,�IEC�454-3-1 Additional�Info tesa®�53938�has�a�IMQ�&�SEMKO�certification�and�meets�IEC�454-3-1�specification. Page�1�of�1�/�As�of��05/20/10 tesa�UK�Ltd. Yeomans�Drive,�Blakelands Milton�Keynes,�Bucks�MK�14�5LS Phone:�+44�(1)�908�211�333 Fax:�+44�(1)�908�211�555 ukenquiry@tesa.com www.tesa.co.uk tesa®�products�prove�their�impressive�quality�day�in,�day�out�in�demanding�conditions�and�are�regularly�subjected�to�strict controls.�All�information�and�recommendations�are�provided�to�the�best�of�our�knowledge�on�the�basis�of�our�practical experience.�Nevertheless�tesa�SE�can�make�no�warranties,�expressed�or�implied,�including,�but�not�limited�to�any�implied warranty�of�merchantability�or�fitness�for�a�particular�purpose.�Therefore,�the�user�is�responsible�for�determining�whether the�tesa®�product�is�fit�for�a�particular�purpose�and�suitable�for�the�user’s�method�of�application.�If�you�are�in�any�doubt, our�technical�support�staff�will�be�glad�to�advise�you.
53948-00042-07 价格&库存
很抱歉,暂时无法提供与“53948-00042-07”相匹配的价格&库存,您可以联系我们找货
