productinformation
tesa® 64958
1050 µm double sided PE foam tape
tesa® 64958 is a white double sided tape for general mounting with a PE foam backing and a synthetic rubber adhesive.
Product benefits:
Highly conformable PE-foam
High immediate bonding strength even on rough or uneven surfaces
High bonding strength at low mounting pressure
High bonding strength on low surface energy substrates
Main Application
Construction of POS-displays
Mounting of indoor signs and posters
Mounting of shelf edge labelling systems
Additional dampening and anti-rattle
Technical Data
Backing material
Color
Total thickness
Type of adhesive
Elongation at break
PE foam
white
1050 µm
synthetic rubber
200 %
Tensile strength
Type of liner
Colour of liner
Thickness of liner
Weight of liner
7 N/cm
glassine
yellow
70 µm
80 g/m²
Steel (after 14 days)
PC (after 14 days)
PE (after 14 days)
PET (after 14 days)
PP (after 14 days)
PVC (after 14 days)
Resistance to chemicals
Softener resistance
Static shear resistance at 23°C
Static shear resistance at 40°C
Adhesion to
Steel (initial)
PC (initial)
PE (initial)
PET (initial)
PP (initial)
PVC (initial)
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
Temperature resistance short term
Temperature resistance long term
Tack
Ageing resistance (UV)
Humidity resistance
Evaluation across relevant tesa® assortment:
60 °C
40 °C
very good
good
medium
low
For latest information on this product please visit http://l.tesa.com/?ip=64958
tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical
information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered
as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not
limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa®
product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be
glad to support you.
Page 1 of 2 - As of 13/09/2019 - en
Properties
tesa® 64958
Additional Information
Liner variants:
PV0 brown glassine paper (71 µm)
Peel Adhesion:
immediately: foam splitting on Steel, Aluminium, ABS, PC, PS, PET, PVC, PE
after 14 days: foam splitting on Steel, Aluminium, ABS, PC, PS, PET, PVC, PP, PE
Page 2 of 2 - As of 13/09/2019 - en
很抱歉,暂时无法提供与“64958-00003-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+94.76592
- 10+90.98570
- 20+87.18465
