74662, BLACK, 25M X 50MM
    TESA
    TESA - 74662, BLACK, 25M X 50MM - Tape, Duct, Black, 25 m x 50 mm
74662, BLACK, 25M X 50MM 数据手册
tesa® Professional 74662 STRONG Duct tape Product Information Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. Technical Data • Backing material • Total thickness • Type of adhesive • Elongation at break PE-film with PETfilament 215 µm synthetic rubber 19 % Adhesion to • steel Properties • Hand tearability • Straight tear edges • Easy to remove • Easy to write on 8.0 N/cm no no Evaluation across relevant tesa® assortment:   • Tensile strength • Temperature resistance max. • Mesh • Unwind force 40 N/cm 60 °C 27 count per square inch 2 N/cm • rough surfaces 6.5 N/cm • Tack • Abrasion resistance • Water resistant  very good      good      medium      low Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=74662 Page 1 of 1 – as of 11/01/22 – en-GB tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
74662, BLACK, 25M X 50MM 价格&库存
很抱歉,暂时无法提供与“74662, BLACK, 25M X 50MM”相匹配的价格&库存,您可以联系我们找货
