04317-00013-00
04317-00013-00
    TESA
    TESA - 04317-00013-00 - Masking Tape, Crepe Paper, White, 50 m x 19 mm
04317-00013-00 数据手册
tesa® 4317 Product Information Fine Crepe Paper Masking Tape for Spray Painting tesa® 4317 is a thin and flexible masking tape comprised of a fine crepe paper backing and a natural rubber adhesive. The masking tape is suitable for a wide range of general masking applications without or with subsequent oven-drying up to a temperature of 80°C. tesa® 4317 is also resistant to wet sanding. The natural rubber adhesive provides an excellent adhesion to multiple surfaces, like metal, rubber, glass and plastic. The fine crepe paper backing is flexible and conformable and is easy to tear by hand. Paints and fillers adhere well to the reverse side, preventing any kind of flaking. Main Application • • • • • • • tesa® 4317 is a flexible masking tape used for spray-painting, painting, and varnishing applications The masking tape has excellent holding power on various surfaces The tape is suitable for oven-drying with temperatures of up to 80°C Ideal for lacquering work Good flexibility for curves Can be used on painted metal, rubber, glass and chrome parts The tape is easy to remove and is hand-tearable Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. • Total thickness • Type of adhesive slightly-creped paper 140 µm natural rubber Adhesion to • steel Properties • Hand tearability • Easy to remove • Paint anchorage • Elongation at break • Tensile strength • Temperature resistance 10 % 38 N/cm 80 °C 3.3 N/cm Yes Evaluation across relevant tesa® assortment:   For latest information on this product please visit http://l.tesa.com/?ip=04317 • Sharp color edge • Conformability  very good      good      medium      low Page 1 of 2 – as of 08/10/21 – en-US Technical Data • Backing material tesa® 4317 Product Information Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=04317 Page 2 of 2 – as of 08/10/21 – en-US tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
04317-00013-00 价格&库存
很抱歉,暂时无法提供与“04317-00013-00”相匹配的价格&库存,您可以联系我们找货
  • 1+18.00553
  • 15+17.49525
  • 40+16.96414
库存:122
