tesa® 4317
Product Information
Fine Crepe Paper Masking Tape for Spray Painting
tesa® 4317 is a thin and flexible masking tape comprised of a fine crepe paper backing and a natural rubber adhesive.
The masking tape is suitable for a wide range of general masking applications without or with subsequent oven-drying up
to a temperature of 80°C. tesa® 4317 is also resistant to wet sanding. The natural rubber adhesive provides an excellent
adhesion to multiple surfaces, like metal, rubber, glass and plastic. The fine crepe paper backing is flexible and conformable
and is easy to tear by hand. Paints and fillers adhere well to the reverse side, preventing any kind of flaking.
Main Application
tesa® 4317 is a flexible masking tape used for spray-painting, painting, and varnishing applications
The masking tape has excellent holding power on various surfaces
The tape is suitable for oven-drying with temperatures of up to 80°C
Ideal for lacquering work
Good flexibility for curves
Can be used on painted metal, rubber, glass and chrome parts
The tape is easy to remove and is hand-tearable
Technical Information (average values)
The values in this section should be considered representative or typical only and should not be used for specification
purposes.
• Total thickness
• Type of adhesive
slightly-creped
paper
140 µm
natural rubber
Adhesion to
• steel
Properties
• Hand tearability
• Easy to remove
• Paint anchorage
• Elongation at break
• Tensile strength
• Temperature resistance
10 %
38 N/cm
80 °C
3.3 N/cm
Yes
Evaluation across relevant tesa® assortment:
For latest information on this product please visit
http://l.tesa.com/?ip=04317
• Sharp color edge
• Conformability
very good
good
medium low
Page 1 of 2 – as of 08/10/21 – en-US
Technical Data
• Backing material
tesa® 4317
Product Information
Disclaimer
Page 2 of 2 – as of 08/10/21 – en-US
tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict
controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical
experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied
warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether
the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our
technical support staff will be glad to support you.
很抱歉,暂时无法提供与“04317-00002-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+23.47279
- 15+22.77507
- 40+22.08775
