07063-00012-22
07063-00012-22
    TESA
    TESA - 07063-00012-22 - Foam Tape, Double Sided, Acrylic, Black, 25 m x 25 mm
07063-00012-22 数据手册
plus tesa® ACX Product Information 7063 ACXplus High Adhesion 800µm tesa® ACXplus 7063 is a black acrylic foam tape. It consists of a high-performance acrylic system and is primarily characterised by its bonding power, stress dissipation and its temperature and weather resistance. Due to its unique formulation it combines a very high adhesion level with a very good resistance against plasticizer migration. It is especially designed for the bonding of “hard-to-bond-materials” such as powder coatings or plastic materials. Even for combinations of such materials with all kind of metals, or metal/metal bonding, it offers a convenient solution due to high process safety. The visco-elastic, foamed acrylic core compensates different thermal elongation of bonded parts. The product provides a very high immediate tack and peel adhesion.tesa® ACX plus 7063 is a black acrylic foam tape. It consists of a high-performance acrylic system and is primarily characterised by its bonding power, stress dissipation and its temperature and weather resistance. Due to its unique formulation it combines a very high adhesion level with a very good resistance against plasticizer migration. It is especially designed for the bonding of “hard-to-bond-materials” such as powder coatings or plastic materials. Even for combinations of such materials with all kind of metals, or metal/metal bonding, it offers a convenient solution due to high process safety. The visco-elastic, foamed acrylic core compensates different thermal elongation of bonded parts. The product provides a very high immediate tack and peel adhesion. Main Application Bonding of hard-to-bond materials such as • Bumper rails • Powder coated blades and panels • Air distributaries Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. Adhesion to • Steel (after 3 days) • Aluminium (after 3 days) foamed acrylic deep black 800 µm 30.0 N/cm 32.0 N/cm For latest information on this product please visit http://l.tesa.com/?ip=07063 • Type of adhesive • Elongation at break • Glass (after 3 days) • PMMA (after 3 days) tackified acrylic 600 % 32.0 N/cm 27.0 N/cm Page 1 of 2 – as of 19/10/21 – en-GB Technical Data • Backing material • Colour • Total thickness plus tesa® ACX Product Information Properties • Temperature resistance short term • Temperature resistance long term • Tack • Ageing resistance (UV) • Humidity resistance 7063 170 °C 70 °C Evaluation across relevant tesa® assortment:   • • • • • Resistance to chemicals Softener resistance Static shear resistance at 23°C Static shear resistance at 70°C T-block  very good      good      medium      low Additional Information PV 22 = White PE coated paper liner tesa® ACX plus branded PV 24 = Blue filmic liner Adhesion values to PMMA, glass and aluminum are not part of the product specification. tesa® ACX plus 7063 is recognised according to UL Standard 746C. UL File QOQW2.E309290 Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=07063 Page 2 of 2 – as of 19/10/21 – en-GB tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
07063-00012-22 价格&库存
很抱歉,暂时无法提供与“07063-00012-22”相匹配的价格&库存,您可以联系我们找货
