64958-00002-00
64958-00002-00
    TESA
64958-00002-00 数据手册
productinformation tesa® 64958 1050 µm double sided PE foam tape tesa® 64958 is a white double sided tape for general mounting with a PE foam backing and a synthetic rubber adhesive. Product benefits: ▪ ▪ ▪ ▪ Highly conformable PE-foam High immediate bonding strength even on rough or uneven surfaces High bonding strength at low mounting pressure High bonding strength on low surface energy substrates Main Application ▪ ▪ ▪ ▪ Construction of POS-displays Mounting of indoor signs and posters Mounting of shelf edge labelling systems Additional dampening and anti-rattle Technical Data ▪ ▪ ▪ ▪ ▪ Backing material Color Total thickness Type of adhesive Elongation at break PE foam white 1050 µm synthetic rubber 200 % ▪ ▪ ▪ ▪ ▪ Tensile strength Type of liner Colour of liner Thickness of liner Weight of liner 7 N/cm glassine yellow 70 µm 80 g/m² ▪ ▪ ▪ ▪ ▪ ▪ Steel (after 14 days) PC (after 14 days) PE (after 14 days) PET (after 14 days) PP (after 14 days) PVC (after 14 days) ▪ ▪ ▪ ▪ Resistance to chemicals Softener resistance Static shear resistance at 23°C Static shear resistance at 40°C Adhesion to ▪ ▪ ▪ ▪ ▪ ▪ Steel (initial) PC (initial) PE (initial) PET (initial) PP (initial) PVC (initial) 4.0 N/cm 4.0 N/cm 4.0 N/cm 4.0 N/cm 4.0 N/cm 4.0 N/cm 4.0 N/cm 4.0 N/cm 4.0 N/cm 4.0 N/cm 4.0 N/cm 4.0 N/cm ▪ ▪ ▪ ▪ ▪ Temperature resistance short term Temperature resistance long term Tack Ageing resistance (UV) Humidity resistance Evaluation across relevant tesa® assortment: 60 °C 40 °C very good good medium low For latest information on this product please visit http://l.tesa.com/?ip=64958 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you. Page 1 of 2 - As of 13/09/2019 - en Properties tesa® 64958 1050 µm double sided PE foam tape Additional Information Liner variants: ▪ PV0 brown glassine paper (71 µm) Peel Adhesion: immediately: foam splitting on Steel, Aluminium, ABS, PC, PS, PET, PVC, PE after 14 days: foam splitting on Steel, Aluminium, ABS, PC, PS, PET, PVC, PP, PE Page 2 of 2 - As of 13/09/2019 - en ▪ ▪ For latest information on this product please visit http://l.tesa.com/?ip=64958 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All technical information and data above mentioned are provided to the best of our knowledge on the basis of our practical experience. They shall be considered as average values and are not appropriate for a specification. Therefore tesa SE can make no warranties, expressed or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. The user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
64958-00002-00 价格&库存
很抱歉,暂时无法提供与“64958-00002-00”相匹配的价格&库存,您可以联系我们找货
