productinformation
tesa® 4957
Double-sided PE-foam mounting tape
tesa® 4957 is a double-sided PE-foam tape for general mounting applications. It consists of a highly conformable PE-foam
backing and a tackified acrylic adhesive. tesa® 4957 has been externally certified for window bar mounting.
Product benefits:
Versatile adhesive for high immediate adhesion on numerous substrates
Fully outdoor suitable: UV, water and ageing resistant
Compensates for differing thermal expansion of dissimilar materials
High immediate bonding strength even at low bonding pressure
Very good cold shock absorbtion
Main Application
POS displays, exhibition sample displays
Shelf edge labels
Cable channels, window bars, window skirting trims
Decorative glass or mirror elements on furniture
Solar module frames
Technical Data
Backing material
Color
Total thickness
PE foam
black/white
1100 µm
Type of adhesive
Elongation at break
Tensile strength
Steel (after 14 days)
ABS (after 14 days)
Aluminium (after 14 days)
PC (after 14 days)
PE (after 14 days)
PET (after 14 days)
PP (after 14 days)
PS (after 14 days)
PVC (after 14 days)
tackified acrylic
200 %
6 N/cm
Adhesion to
Steel (initial)
ABS (initial)
Aluminium (initial)
PC (initial)
PE (initial)
PET (initial)
PP (initial)
PS (initial)
PVC (initial)
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
1.7 N/cm
4.0 N/cm
1.8 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
4.0 N/cm
2.2 N/cm
4.0 N/cm
3.3 N/cm
4.0 N/cm
4.0 N/cm
Page 1 of 2 - as of 04/09/2019 - ei
For latest information on this product please visit http://l.tesa.com/?ip=04957
tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information
and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no
warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore,
the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application.
If you are in any doubt, our technical support staff will be glad to support you.
tesa® 4957
Properties
Temperature resistance short term
Temperature resistance long term
Tack
Ageing resistance (UV)
Humidity resistance
80 °C
80 °C
Evaluation across relevant tesa® assortment:
very good
Resistance to chemicals
Softener resistance
Static shear resistance at 23°C
Static shear resistance at 40°C
good
medium
low
Additional Information
Liner variants:
PV0 brown glassine paper (70 µm)
PV4 white with tesa® logo PE-coated paper (122 µm)
PV6 blue PP (80 µm)
PV12 transparent PET (75µm)
PV15 blue PE (100 µm)
tesa® 4957 has been tested and approved by IFT institute for window bar mounting. The test includes UV, driving rain and
windload. (IFT report number 509 30742/1).
tesa® 4957 has been tested by TÜV Rheinland, Germany. The test confirms the longterm adhesion performance after IEC 61215 /
61646 climate tests and a 85°C temperature resistance. (TÜV report number 21209595).
Page 2 of 2 - as of 04/09/2019 - ei
Peel Adhesion:
- immediately: foam splitting on Steel, Aluminium, ABS, PC, PS, PET, PVC
- after 14 days: foam splitting on Steel, Aluminium, ABS, PC, PS, PET, PVC
很抱歉,暂时无法提供与“04957-00009-00”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+185.88700
- 10+182.02346
- 20+177.64965
