07055-00011-28
07055-00011-28
    TESA
    TESA - 07055-00011-28 - Tape, Double Sided, Acrylic, Acrylic Adhesive, Transparent, 25 m x 19 mm
07055-00011-28 数据手册
plus tesa® ACX 7055 High Transparency Product Information 1000 µm double-sided acrylic core tape tesa® ACXplus 7055 is a double-sided transparent acrylic core tape. It consists of a high performance acrylic system and is identified by its bonding power, stress dissipation and its temperature and weather resistance. Due to the product’s unique formulation, this double-sided acrylic core tape combines high adhesion levels with the ability to absorb and dissipate high dynamic loads. The viscoelastic core of the product is able to compensate for thermal elongations of bonded parts. tesa® ACXplus 7055 is especially suitable for constructive bonding of transparent and translucent materials such as glass or acrylic to receive a seamless and optical clear bonding. In addition, it is recommended for outdoor applications. Main Application The tesa® ACX plus product family is suitable for a wide range of constructive bonding applications. To ensure the highest performance possible, our aim is to fully understand the application (including the substrates involved) in order to provide the right product recommendation. Example mounting applications of transparent and translucent materials include but are not limited to: • • • • Plissee profiles Partition walls (glass on glass) Signage (PMMA on aluminum) Extruded profiles Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. Adhesion to • Steel (initial) • Aluminium (initial) • Glass (initial) • PMMA (initial) solid acrylic transparent 1000 µm 15.0 N/cm 13.0 N/cm 16.0 N/cm 13.0 N/cm For latest information on this product please visit http://l.tesa.com/?ip=07055 • Type of adhesive • Elongation at break • • • • Steel (after 3 days) Aluminium (after 3 days) Glass (after 3 days) PMMA (after 3 days) pure acrylic 1000 % 24.0 N/cm 24.0 N/cm 24.0 N/cm 17.0 N/cm Page 1 of 3 – as of 01/11/21 – en-US Technical Data • Backing material • Color • Total thickness plus tesa® ACX 7055 High Transparency Product Information Properties • Temperature resistance short term • Temperature resistance long term • Tack • Ageing resistance (UV) • Humidity resistance 200 °C 100 °C Evaluation across relevant tesa® assortment:   • • • • • Resistance to chemicals Softener resistance Static shear resistance at 23°C Static shear resistance at 70°C T-block  very good      good      medium      low Additional Information Please note that we recommend using tesa® Adhesion Promoter as a surface pre-treatment. It leads to a significant improvement in adhesion levels, avoids moisture infiltration, and promotes long-term resistance against harsh environmental factors. Which tesa® Adhesion Promoter should be used depends on the substrates and the application. We will be glad to advise you in order to find the right solution. For permanent outdoor applications with load-bearing requirements, our first recommendation is tesa® ACX High Resistance. plus 707x Selected product thicknesses of our 705x series are available with adhesive neutralized edges. Liner versions: • • • • • PV12: Transparent PET liner – unbranded PV26: White paper liner – unbranded PV28: Blue film liner – unbranded PV48: White film liner – branded Further liner versions might be available upon request. Certificates: For latest information on this product please visit http://l.tesa.com/?ip=07055 Page 2 of 3 – as of 01/11/21 – en-US • tesa® ACX plus 7055 is recognized according to UL Standard 746C. UL File QOQW2.E309290 • tesa® ACX plus 7055 is recognized according to UL Standard 879. UL File UYMR2.E479260 • TÜV Rheinland: Static shear test including mathematical extrapolation up to ten years plus tesa® ACX 7055 High Transparency Product Information Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=07055 Page 3 of 3 – as of 01/11/21 – en-US tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
07055-00011-28 价格&库存
很抱歉,暂时无法提供与“07055-00011-28”相匹配的价格&库存,您可以联系我们找货
    • 1+550.27757
    库存:5
