50565-00000-01
50565-00000-01
    TESA
50565-00000-01 数据手册
productinformation tesa® 50565 Strong 50µm aluminium tape with and without liner (PV1 and PV0) tesa® 50565 is a strong aluminium tape, based on a 50µm aluminium foil and an acrylic adhesive. tesa® 50565 is mainly used in the appliance industry and also for a wide range of other applications. Features: ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ ▪ good adhesion mechanical resistance moisture resistant vapour tight high thermal conductivity oil & acid resistant ageing-resistant available without liner (PV0) and with liner (PV1) flame retardant (UL510) Main Application ▪ ▪ ▪ ▪ Mounting of refrigeration coils General purpose temperature insulation Sealing of ducts Masking, protecting, repairing, closing ...and a lot more! Technical Data ▪ ▪ ▪ ▪ ▪ Backing material Total thickness Type of adhesive Adhesion to steel Elongation at break aluminium foil 90 µm acrylic 6 N/cm 8% ▪ ▪ ▪ ▪ Tensile strength Temperature resistance min. Temperature resistance max. Surface finish ▪ ▪ Abrasion resistance Water resistance 35 N/cm -40 °C 160 °C reflective Properties ▪ ▪ ▪ Hand tearability Suitable for die cutting Certified according to very good good medium low Page 1 of 1 - as of 31/10/2019 - ei Evaluation across relevant tesa® assortment: yes UL 510 Flame retardancy For latest information on this product please visit http://l.tesa.com/?ip=50565 tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
50565-00000-01 价格&库存
很抱歉,暂时无法提供与“50565-00000-01”相匹配的价格&库存,您可以联系我们找货
    • 1+246.29766
    库存:16
