04934-00000-00
04934-00000-00
    TESA
    TESA - 04934-00000-00 - Tape, Double Sided, Cloth, Synthetic Rubber Adhesive, White, 25 m x 25 mm
04934-00000-00 数据手册
tesa® 4934 Product Information Double-sided fabric tape tesa® 4934 is a double-sided tape. It consists of a fabric backing with a thick, tacky adhesive coating. The synthetic rubber adhesive is solvent free. tesa® 4934 is a general purpose mounting tape. tesa® 4934 is easily hand tearable. Main Application Due to the flexible fabric backing and the high coating weight it is particularly suited for mounting on rough, fibrous surfaces, for example carpet laying. Technical Information (average values) The values in this section should be considered representative or typical only and should not be used for specification purposes. cloth white 200 µm synthetic rubber Adhesion to • Steel (initial) • PE (initial) • PP (initial) • PVC (initial) Properties • Temperature resistance short term • Temperature resistance long term • Tack • Ageing resistance (UV) • Humidity resistance 14.5 N/cm 8.0 N/cm 16.0 N/cm 14.0 N/cm 60 °C 40 °C Evaluation across relevant tesa® assortment:   For latest information on this product please visit http://l.tesa.com/?ip=04934 • Elongation at break • Tensile strength • Type of liner 20 % 35 N/cm glassine • • • • Steel (after 14 days) PE (after 14 days) PP (after 14 days) PVC (after 14 days) • • • • Static shear resistance at 23°C Static shear resistance at 40°C Static shear resistance at 70°C Fogging  very good      good     24.0 N/cm 8.5 N/cm 24.5 N/cm 22.5 N/cm  medium      low Page 1 of 2 – as of 08/10/21 – en-US Technical Data • Backing material • Color • Total thickness • Type of adhesive tesa® 4934 Product Information Disclaimer For latest information on this product please visit http://l.tesa.com/?ip=04934 Page 2 of 2 – as of 08/10/21 – en-US tesa® products prove their impressive quality day in, day out in demanding conditions and are regularly subjected to strict controls. All information and recommendations are provided to the best of our knowledge on the basis of our practical experience. Nevertheless tesa SE can make no warranties, express or implied, including, but not limited to any implied warranty of merchantability or fitness for a particular purpose. Therefore, the user is responsible for determining whether the tesa® product is fit for a particular purpose and suitable for the user’s method of application. If you are in any doubt, our technical support staff will be glad to support you.
04934-00000-00 价格&库存
很抱歉,暂时无法提供与“04934-00000-00”相匹配的价格&库存,您可以联系我们找货
