105718
105718
    BRADY
105718 数据手册
Technical Data Sheet Steel Group Lockout Hasps with Tabs TDS No. LOTO­64 Effective Date: 11/20/2012 Description:   Design Tamper­proof interlocking tabs prevent unauthorized opening Constructed of case­hardened steel with rust proof plating and bright red vinyl insulation Available in 1" and 1 1/2" diameter jaws Standard package: 1 hasp Material Steel Hardened with Rust Proof Plating Vinyl Coating: Red   Temperature Range Steel: ­30°F to 350°F (­35°C to 177°C) Vinyl Coating: ­30°F to 200°F (­35°C to 95°C) Chemical Resistance All approved chemicals listed are based on the manufactures specified chemical resistance chart for plastic material only. Chemical °C Chemical °C Acetone 25 Petroleum 25 Acetone 60 Turpentine oil 25 Chlorine, chlorine water 25 Turpentine substitute (white spirit) 25 Fuel, engine: Gasoline (normal & premium grade) 85 Trichloroethane 1,1,1 45 Lubrication oil: gear oil
105718 价格&库存
很抱歉,暂时无法提供与“105718”相匹配的价格&库存,您可以联系我们找货
    • 1+91.17315
    库存:128
    105718
    库存:132
