Technical Data Sheet
BRADY B481 StainerBondz (TM)
TDS No. B481
Effective Date: 02/28/2011
Description:
GENERAL
Print Technology: Thermal transfer
Material Type: Polyester
Finish: Matte white
Adhesive: Permanent acrylic
APPLICATIONS
Slide labeling and other lab identification
RECOMMENDED RIBBONS
Brady Series R6400
REGULATORY
Brady B481 is RoHS compliant to 2005/618/EC MCV amendment to RoHS Directive 2002/95/EC.
SPECIAL FEATURES
B481, when printed with the R6400 thermal transfer ribbon, is designed for use in the slide staining process and other
laboratory identification which requires superior chemical resistance. B481 performs well in the commonly used H & E
(hematoxilin and eosin) slide staining process.
Details:
PHYSICAL PROPERTIES
Thickness
Adhesion to:
Glass
Polypropylene
Stainless steel
Tack
Tensile strength and Elongation
TEST METHODS
ASTM D 1000
Total (excluding liner)
20 minute dwell
24 hour dwell
20 minute dwell
24 hour dwell
20 minute dwell
24 hour dwell
ASTM D 2979
PolykenTM Probe Tack
1 second dwell
ASTM D 1000
Machine direction
AVERAGE RESULTS
0.0033 inches (0.0838 mm)
74 oz/inch (81.4 N/100mm)
77 oz/inch (84.7 N/100mm)
73 oz/inch (80.3 N/100mm)
76 oz/inch (83.6 N/100mm)
78 oz/inch (85.8 N/100mm)
37oz (1060 grams)
40 lbs/inch (704 N/100mm), 75%
PERFORMANCE PROPERTIESENVIRONMENTAL RESISTANCE
B481 samples were printed with the R6400 Series ribbon on BradyprinterTM THT Model 300XPlus thermal transfer printer.
Printed samples were laminated to glass microscope slides and then exposed to the indicated environmental conditions.
PERFORMANCE
TEST METHODS
EFFECT TO LABEL
EFFECT TO PRINT IMAGE
PROPERTIES
High Service Temperature
30 days at 266°F (130°C)
Slight yellowing at 130°C,
No visible effect
moderate yellowing at 145°C
Low Service Temperature
30 days at 112°F (80°C)
No visible effect
No visible effect
30 days at 100°F (37°C), 80% No visible effect
No visible effect
Humidity Resistance*
relative humidity
Ramp time 2830 minutes,
No visible effect if slides were
peak temperature 125°C , peak placed on the rack flat. Slight
Sterilizer resistance (autoclave pressure 21psi and peak
water mark at the bottom edge No visible effect
duration 5 minutes, Sterilemax if slides were placed on the
resistance)
Table Top Steam Sterilizer,
rack vertically
Series 1277
Taber Abraser, CS10 grinding No visible effect
Print still legible after 150
wheels, 500 g/arm, 150 cycles
cycles
*B481 is not recommended for use in conditions where both high temperature and high humidity greater than 95°F (35°C)
and 80% relative humidity are present.
PERFORMANCE PROPERTIESCHEMICAL RESISTANCE
Abrasion Resistance
B481 samples were printed with R6400 Series ribbon on BradyprinterTM THT Model 300XPlus thermal transfer printer.
Printed samples were laminated to aluminum panels and allowed to dwell 24 hours prior to testing. Testing consisted of 5
cycles of 10 minute immersions in the specified chemical followed by 30 minute recovery peroids. After the final immersion
the printed image was rubbed 10 times with a cotton swab saturated with the test fluid. Testing was conducted at room
temperature.
EFFECT TO
EFFECT TO
EFFECT TO
CHEMICAL REAGENT
PRINT/TOPCOAT
PRINT/TOPCOAT
ADHESIVE
WITHOUT RUB
WITH RUB
Acetone
1
1
1
Ethanol
1
1
1
Toluene
1
1
2
Isopropanol
1
1
1
Xylene
1
1
2
MEK
1
1
1
Deionized Water
1
1
1
Dimethylsulfoxide (DMSO)
1
1
1
3% Alconox® Detergent
1
1
1
50% Acetic Acid
1
1
1
10% Sulfuric Acid
1
1
1
10% Clorox® Bleach Solution
1
1
1
10% Sodium Hydroxide
5, topcoat delamination
5
1
Rating scale:
1=no visible effect
2=slight smear or print removal or adhesive oozing, detectable but minimal
3=moderate smear or print removal or adhesive oozing
4=severe smear or print removal or adhesive oozing
5=complete smear, print removal or topcoat removal (delamination) or adhesive oozing
PERFORMANCE PROPERTIESSlide Staining Test
Samples of B481 printed with R6400 Series ribbon were laminated to glass microscope slides. These slides were placed in
the Leica AutoStainer XL automated slide stainer. The slides were processed using the H&E (hematoxilin and eosin) staining
process.
Labels were adhered to the following brands of slides:
ColeParmer® precleaned frosted, precleaned Superfrost® and plain precleaned Superfrost®
Fisher Scientific – precleaned frosted beveled
Erie Scientific precleaned Superfrost® plus
Mercedes Medical (precleaned, belveled edge, double frost)
Gold Seal Products® Gold Seal® precleaned
DURATION
REAGENT
STATION
STEP
(minutes)
None
Oven
1
10:00
Xylene
1
2
2:00
Xylene
2
3
2:00
100% denatured ethanol
3
4
2:00
4
5
2:00
70% denatured ethanol
5
6
1:00
Wash (tap water)
Wash 1
7
2:00
Hematoxilin stain (Harris formula modified, supplied by Ricca Chemical Company)
6
8
5:00
Wash (tap water)
Wash 2
9
2:00
Acid Alcohol (mixture of 1.25% of concentrated HCl, 69.26% of ethanol and 29.49% of
7
10
0.02
DI H2O)
Wash (tap water)
Wash 3
11
3:00
Scott’s bluing reagent (supplied by Fisher Scientific)
8
12
3:00
Wash (tap water)
Wash 4
13
3:00
Eosin Y stain (Stock formula, 1% alcoholic solution supplied by Ricca Chemical
14
14
2:00
Company)
95% denatured ethanol
15
15
0:30
16
16
2:00
17
17
2:00
18
18
2:00
Xylene
Exit
19
30:00
Test results: All the labels remained adhered to all types of slides through the process. Print was not affected. Label
surface was slightly pink after the process.
Product testing, customer feedback, and history of similar products, support a customerperformance expectation of at least two
years from the date of receipt for this product as long as this product is stored in its original packaging in an environment
below 80 degrees F (27°C) and 60% RH . We are confident that our product will perform well beyond this time frame. However,
it remains the responsibility of the user to assess the risk of using such product. We encourage customers to develop functional
testing protocols that will qualify a product's fitness for use, in their actual applications.
Processed slides labeled with B481 should be stored in an environment below 80°F (27°C) and 60% RH.
Trademarks:
ASTM: American Society for Testing and Materials (U.S.A.)
Alconox® is a registered trademark of Alconox Co.
BradyPrinter™ is a trademark of Brady Worldwide, Inc.
Clorox® is a registered trademark of The Clorox Company
ColeParmer® is a registered trademark of the ColeParmer Instrument Company
Gold Seal® is a registered trademark of Erie Scientific Company
Polyken™ is a trademark of Testing Machines Inc.
Superfrost® is a registered trademark of Erie Scientific Company
Note: All values shown are averages and should not be used for specification purposes.
Test data and test results contained in this document are for general information only and shall not be relied upon by Brady
customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to
develop specifications or performance criteria for specific product applications should contact Brady for further information.
Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to
manufacture this product or based on results of testing using recognized analytical methods performed by a third party,
independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and
assumes no liability in connection with the use of this information.
WARRANTY
Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their
adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and
workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have
been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers.
This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of
merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no
circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection
with the use, or inability to use, Brady's products.
Copyright 2016 Brady Worldwide, Inc. | All Rights Reserved
Material may not be reproduced or distributed in any form without written permission.
Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 4143586600 | Fax: 8002922289
很抱歉,暂时无法提供与“B33-194-481”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1998.078081+259.68991
