B33-340-718
B33-340-718
    BRADY
    B33,B718,WHITE
B33-340-718 数据手册
Technical Data Sheet BRADY B-718 THERMAL TRANSFER PRINTABLE GLOSSY WHITE LOW PROFILE STATIC DISSIPATIVE POLYIMIDE LABEL STOCK TDS No. B-718 Effective Date: 01/21/2019 Description: GENERAL Print Technology: ​Thermal transfer Material Type: ​Polyimide Finish: ​Glossy Adhesive: ​Static Dissipative Permanent Acrylic APPLICATIONS Printed circuit board and electronic component pre-process labeling RECOMMENDED RIBBONS Brady Series R6000 Halogen Free REGULATORY/AGENCY APPROVALS: UL: ​Brady B-718 is a UL Recognized Component to UL969 Labeling and Marking Standard when printed with the Brady Series R6000 Halogen Free ribbon. See UL file MH17154 for specific details. UL information can be accessed on-line at UL.com in the UL Product iQ area. For information on the Weee-RoHS compliance status for a Brady Product go to one of the following websites: In Canada: ​www.bradycanada.ca/weee-rohs In Europe: ​www.bradyeurope.com/rohs In Japan: ​ www.​brady.co.jp/products/labelsuse/rohs All other regions: ​www.bradyid.com/weee-rohs SPECIAL FEATURES B-718 is constructed with a static dissipative adhesive. This product has adhesive surface resistivity values in the recommended range for dissipative ESD packaging materials as defined by ANSI/ESD S5412008 (between 10​4​ and 10​11​ ohms). B-718 has a low profile (1 mil) film allowing for easier use in processes which demand thin and/or lighter weight label Materials. B-718 in combination with the Brady Series R6000 Halogen Free ribbon meets the requirements of MIL-STD-202G, Method 215K. Preheat can be employed to further enhance print permanence in the case of extreme solvent and/or abrasion exposure. B-718 is designed to withstand multiple cycles of harsh condition washes for printed circuit boards. Details: PHYSICAL PROPERTIES Thickness Adhesion to: -Stainless Steel Tack TEST METHODS ASTM D1000 -Substrate -Adhesive -Total (excluding liner) ASTM D1000 20 minute dwell 24 hour dwell ASTM D2979 AVERAGE RESULTS 0.0016 inch (0.041mm) 0.0017 inch (0.043 mm) 0.0033 inch (0.084 mm) 40 oz/in (44 N/100 mm) 47 oz/in (51 N/100 mm) Drop Shear Dielectric Strength Adhesive Surface Resistivity Polyken™ Probe Tack 0.5 second dwell PSTC-7 (except use ½” x 1” sample) ASTM D1000 EOS/ESD STM11.11 49 oz (1400 g) >100 hours 9800 volts total 5.9 x 10​7​ ohms/sq Performance properties tested on B-718 printed with the Brady Series R6000 Halogen Free ribbon. Printed samples of B-718 were laminated to aluminum and allowed to dwell 24 hours before exposure to the indicated environmental conditions. PERFORMANCE PROPERTIES Short Term High Service Temperature TEST METHODS 80 seconds at various temperatures 5 minutes at various temperatures 2 hours at various temperatures Long Term High Service Temperature 1000 hours at various temperatures Low Service Temperature Humidity Resistance UV Light Resistance Weatherability Salt Fog Resistance Abrasion Resistance Chemical Vapor Phase Resistance AVERAGE RESULTS No visible effect to label at 572°F (300°C), label discolors slightly at 626°F (330°C) but still functional, at 662°F (350°C) label still functional but moderately discolored and adhesive discolored at label edge; print is still legible No visible effect to label at 500°F (260°C), label discolors slightly at 518°F (270°C), at 572°F (300°C) label moderately discolors and adhesive discolors at label edge. Label remains functional. Print is still legible No visible effect to label at 338°F (170°C), label discolors slightly at 374°F (190°C), moderately at 428°F (220°C) and severely at 500°F (260°C). Label remains functional. Print is still legible. No visible effect to label at 212°F (100°C), label discolors slightly at 248°F (120°C), moderately at 293°F (145°C). Label remains functional. Print is still legible. No visible effect No visible effect 1000 hours at -94°F (-70°C) 1000 hours at 100°F (37°C)/95% RH ASTM G155, Cycle 1, Dry 1000 hours Topcoat turns light yellow, label in Q-Sun Xenon Test Chamber remains functional ASTM G155, Cycle 1 1000 hours in Xenon Arc Weather-Ometer® ASTM B117 1000 hours in 5% salt fog solution chamber Taber Abraser, CS-10 grinding wheels, 500 g/arm (Fed. Std. 191A, Method 5306) Label adhered to epoxy PC board and exposed to the vapor of boiling chemical for 10 minutes and then rubbed with a cotton swab saturated with the chemical for 10 rubs Slight discoloration No visible effect Print legible after 100 cycles Test samples were baked 4 minutes at 160°C prior to testing. Ionox® 3955 Severe print removal Micronox® MX 2501 *B-718 is not recommended for outdoor use. Complete print removal PERFORMANCE PROPERTY CHEMICAL RESISTANCE Test samples were printed with the Brady Series R6000 Halogen Free ribbon. Labels were adhered to epoxy PC board. Test samples were exposed to the indicated environments. Test samples were baked 4 minutes at 160°C before testing. All test samples were immersed in the test fluids for 10 minutes prior to rub with cotton swab ten times. CHEMICAL REAGENT SUBJECTIVE OBSERVATION OF VISUAL CHANGE EFFECT TO LABEL R6000 HALOGEN FREE Kyzen Corp, 15% Aquanox® A4625 at 140°F (60°C) Kyzen Corp, 17% Aquanox® A4520 at 140°F (60°C) No visible effect WITHOUT RUB 1 WITH RUB 4 No visible effect 1 3 1 1 1 1 1 5 1 5 1 5 1 5 1 2 1 1 Kyzen Corp, 10% No visible effect Aquanox® A4638 at 150°F (65°C) Kyzen Corp, 20% No visible effect Aquanox® A4703 at 145°F (63°C) Zestron, 15% Atron® No visible effect AC205 at 150°F (65°C) Zestron, 15% Atron® No visible effect AC207 at 150°F (65°C) Zestron, 15% Vigon® A201 No visible effect at 150°F (65°C) Zestron, 15% Vigon® No visible effect N600 at 150°F (65°C) Isopropyl Alcohol 99% at No visible effect 180°F (82°C) Deionized water at 212°F No visible effect (100°C) Rating Scale: 1=no visible effect 2=slight smear or print removal, detectable but minimal smear 3=moderate smear or print removal (print still legible) 4=severe smear or print removal (print illegible or just barely legible) 5=complete print removal PERFORMANCE PROPERTY Chemical Resistance TEST METHOD MIL-STD-202G,Method 215K Test samples were printed with Series R6000 Halogen Free ribbon. Labels were printed with alphanumerics and bar codes. Test samples were subjected to 3 cycles of 3 minute immersions immediately followed by a toothbrush rub after each immersion. TEST FLUID Solvent A 1 part IPA, 3 parts Mineral Spirits Solvent C Terpene Defluxer Solvent D Saponifier @ 70°C RESULTS R6000 HALOGEN FREE Meets requirements Meets requirements Meets requirements Shelf Life: Shelf life is two years from the date of receipt​ for this product as long as this product is stored in its original packaging in an environment below 80° F (27° C) and 60% RH. It remains the responsibility of the user to assess the risk of using this product. ​We encourage customers to develop testing protocols that will qualify a product's fitness for use in their actual application. Trademarks: ANSI: American National Standards Institute (U.S.A.) ASTM: American Society for Testing and Materials (U.S.A.) All S.I. Units (metric) are mathematically derived from the U.S. Conventional Units Aquanox® is a registered trademark of the Kyzen Corporation Atron® is a registered trademark of the Zestron Corporation Ionox® is a registered trademark of the Kyzen Corporation Micronox® is a registered trademark of the Kyzen Corporation PSTC: Pressure Sensitive Tape Council (U.S.A.) Polyken™ is a trademark of Testing Machines Inc. UL: Underwriters Laboratories Inc. (U.S.A.) Vigon® is the registered trademark of Zestron Corporation Weather-Ometer® is a registered trademark of Atlas Material Testing Technology LLC Note: ​All values shown are averages and should not be used for specification purposes. Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2019 Brady Worldwide, Inc. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414-358-6600 | Fax: 800-292-2289
B33-340-718 价格&库存
很抱歉,暂时无法提供与“B33-340-718”相匹配的价格&库存,您可以联系我们找货
B33-340-718
  • 1+4557.448581+592.45357
