B33-5-483
B33-5-483
    BRADY
    LABEL 0.5"H X 1"W WHT 1=5000PCS
B33-5-483 数据手册
Technical Data Sheet BRADY B­483 THERMAL TRANSFER PRINTABLE LABEL STOCK TDS No. B­483 Effective Date: 06/27/2012 Description: GENERAL Print Technology: Thermal transfer Material Type: White Polyester Finish: Glossy Adhesive: Permanent Rubber Based APPLICATIONS B­483 is designed for high adhesion to textured metals and low surface energy plastics.  Print­On­Demand floor labels can be created using ToughStripeTM labels (B­483 colors overlaminated with B­634 clear polyester overlaminate).  ToughStripeTM  labels are designed for use in cartridge form with the GlobalMark® 2 and BMPTM 71 label printer.   RECOMMENDED RIBBONS Brady Series R6000 Brady Series R6000 Halogen Free (previously known as R6000HF) Brady Series R4900 Brady Series R4400 colored thermal transfer ribbons.   REGULATORY/AGENCY APPROVALS UL: B­483 is a UL Recognized Component to UL969 Labeling and Marking Standard when printed with Brady Series R6000 and Series R6000 Halogen Free ribbons.   See UL file MH17154 for specific details. UL information can be accessed on line at UL.com. Search in Certifications area. The Brady Series R4900 ribbon is also UL approved. CSA: B­483 is CSA Accepted to C22.2 No.0.15­95 Adhesive Labels Standard when printed with Brady Series R6000 ribbon. See CSA file 041833 for specific details. CSA information can be accessed online at directories.csa­international.org.   Brady B­483 is RoHS compliant to 2005/618/EC MCV amendment to RoHS Directive 2002/95/EC.   SPECIAL FEATURES B­483 is specifically designed to adhere to powder coated surfaces. Details: PHYSICAL PROPERTIES Thickness Adhesion to: ­Stainless Steel TEST METHODS ASTM D 1000 ­Substrate ­Adhesive ­Total ASTM D 1000 20 minute dwell 24 hour dwell AVERAGE RESULTS   0.0020 inch (0.051 mm) 0.0020 inch (0.051 mm) 0.0040 inch (0.102 mm)   155 oz/in (169 N/100 mm) 160 oz/in (174 N/100 mm) ­Textured ABS 20 minute dwell 24 hour dwell 55 oz/in (60 N/100 mm) 54 oz/in (59 N/100 mm) ­Polypropylene 20 minute dwell 24 hour dwell 140 oz/in (153 N/100 mm) 143 oz/in (156 N/100 mm) ­Painted Enamel 20 minute dwell 24 hour dwell 144 oz/in (157 N/100 mm) 149 oz/in (162 N/100 mm) ­Powder Coated Metal 20 minute dwell 24 hour dwell ASTM D 2979 Polyken™ Probe Tack 0.5 second dwell 102 oz/in (111 N/100 mm) 104 oz/in (113 N/100 mm)   39 oz (1122 g) Tack   Performance properties tested on B­483 printed with Series R6000, R6000 Halogen Free and R4900 ribbons.  Printed samples of B­483 were laminated to aluminum before exposure to the indicated environmental condition. Results the same for both ribbons unless noted otherwise. PERFORMANCE PROPERTIES TEST METHODS TYPICAL RESULTS Long Term High Service Temperature 30 days at 248°F (120°C) No visible effect Long Term Low Service Temperature 30 days at ­40°F (­40°C) No visible effect Humidity Resistance 30 days at 100°F (37°C), 95% R.H. No visible effect UV Light Resistance 30 days in UV Sunlighter™ 100 No visible effect Weatherability ASTM G155, Cycle 1 No visible effect 30 days in Xenon Arc Weatherometer ASTM B 117   Salt Fog Resistance 30 days in 5% salt fog solution chamber No visible effect Abrasion Resistance Taber Abraser, CS­10 grinding wheels, R6000:  Print legible after 100 cycles 250 g/arm (Fed. Std. 191A, Method 5306) R6000  Halogen Free:  Print legible after 100 cycles     PERFORMANCE PROPERTY CHEMICAL RESISTANCE Samples printed with Series R6000, R6000 Halogen Free and R4900 ribbons.  Testing was conducted after 24 hour dwell. Testing consisted of 5 cycles of 10 minute immersions in the specified chemical reagent followed by 30 minute recovery periods. After final immersion, samples rubbed 10 times with cotton swab saturated with test fluid.   CHEMICAL REAGENT SUBJECTIVE OBSERVATION OF VISUAL CHANGE EFFECT TO LABEL R4900 R6000 R6000 Halogen Free STOCK Methyl Ethyl Ketone Slight adhesive ooze No visible effect w/o rub, No visible effect w/o rub, No visible effect w/o rub, complete print removal complete print removal complete print removal after rub after rub after rub 1,1,1­Trichloroethane No visible effect No visible effect w/o rub, No visible effect w/o rub, Obsolete complete print removal complete print removal after rub after rub Toluene No visible effect No visible effect w/o rub, No visible effect w/o rub, No visible effect w/o rub, complete print removal complete print removal complete print removal after rub after rub after rub Isopropyl Alcohol No visible effect No visible effect with or No visible effect with or No visible effect with or without rub without rub without rub Mineral Spirits Slight adhesive ooze No visible effect with or No visible effect with or No visible effect with or without rub without rub without rub JP­8 Jet Fuel No visible effect No visible effect with or No visible effect with or No visible effect with or without rub without rub without rub SAE 20 WT Oil No visible effect No visible effect with or No visible effect with or No visible effect with or without rub without rub without rub Mil 5606 Oil Slight adhesive ooze No visible effect with or No visible effect with or No visible effect with or without rub without rub without rub Speedi Kut Cutting Oil No visible effect No visible effect with or No visible effect with or Not Tested 332 without rub without rub Gasoline No visible effect No visible effect w/o rub, No visible effect w/o rub, No visible effect slight print removal after slight print removal after rub rub Rust Veto® 342 No visible effect No visible effect with or No visible effect with or Not Tested without rub without rub Skydrol® 500B­4 No visible effect Moderate print removal No visible effect w/o rub, No visible effect w/o rub, w/o rub, complete print complete print removal severe print removal removal with rub after rub after rub Super Agitene® Slight adhesive ooze No visible effect with or No visible effect with or No visible effect with or without rub without rub without rub Deionized Water No visible effect No visible effect with or No visible effect with or No visible effect with or without rub without rub without rub 3% Alconox® Detergent No visible effect No visible effect with or No visible effect with or No visible effect with or without rub without without Northwoods™ Buzz Saw No visible effect No visible effect No visible effect Not Tested Citrus Degreaser   ToughStripeTM labels (B­483 colors overlaminated with B­634 clear polyester overlaminate) designed for use in cartridge form with the GlobalMark® 2 and BMPTM 71 label printers were tested in the following chemical reagents.  Samples were allowed to dwell 24 hours at room temperature prior to testing.  Dip testing consisted of 5 cycles of 10 minute immersions in the specified chemicals followed by 30 minute recovery periods.  Samples were immersed in the chemical reagent for 7 days for the 7 day immersion test.   Testing was conducted at room temperature.    CHEMICAL REAGENT 7 DAY IMMERSION DIP TEST 30% Sulfuric Acid NE NE 10% Sulfuric Acid NE NE 30% Hydrochloric Acid F NE 10% Hydrochloric Acid NE NE Glacial Acetic Acid F F 5% Acetic Acid NE NE 50% Sodium Hydroxide F F 10% Sodium Hydroxide F F 10% Ammonia F NE 5% Sodium Hypochlorite (bleach) F NE 10% Sodium Chloride NE NE Methanol F NE Isopropyl Alcohol NE NE Heptane F NE Mineral Spirits F F Turpentine F NE Diesel Fuel NE NE Kerosene F NE Gasoline F NE ASTM #3 Oil NE NE SAE 20 Oil NE NE Alconox® NE NE Water NE NE NE = No Effect F = Failed   Product testing, customer feedback, and history of similar products, support a customer performance expectation of at least two years from the date of receipt for this product as long as this product is stored in its original packaging in an environment below 80 degrees F  (27°C) and 60% RH . We are confident that our product will perform well beyond this time frame. However, it remains the responsibility of the user to assess the risk of using such product. We encourage customers to develop functional testing protocols that will qualify a product's fitness for use, in their actual applications. Trademarks: ASTM: American Society for Testing and Materials (U.S.A.) Alconox® is a registered trademark of Alconox Co. All S.I. Units (metric) are mathematically derived from the U.S. Conventional BMP® is a registered trademark of Brady Worldwide, Inc. BradyPrinter™ is a trademark of Brady Worldwide, Inc. CSA: Canadian Standards Association Globalmark® is a registered trademark of Brady Worldwide, Inc. Northwoods™ is a trademark of the Superior Chemical Corporation Polyken™ is a trademark of Testing Machines Inc. Rust Veto® is a registered trademark of the E.F. Houghton & Co. SAE: Society of Automotive Engineers (U.S.A.) Skydrol® is a registered trademark of the Monsanto Company Sunlighter™ is a trademark of the Test Lab Apparatus Company Super Agitene® is a registered trademark of Graymills Corporation ToughStripe™ is a registered trademark of Brady Worldwide, Inc. UL: Underwriters Laboratories, Inc. Units. Note: All values shown are averages and should not be used for specification purposes.  Test data and test results contained in this document are for general information only and shall not be relied upon by Brady customers for designs and specifications, or be relied on as meeting specified performance criteria. Customers desiring to develop specifications or performance criteria for specific product applications should contact Brady for further information. Product compliance information is based upon information provided by suppliers of the raw materials used by Brady to manufacture this product or based on results of testing using recognized analytical methods performed by a third party, independent laboratory. As such, Brady makes no independent representations or warranties, express or implied, and assumes no liability in connection with the use of this information. WARRANTY   Brady products are sold with the understanding that the buyers will test them in actual use and determine for themselves their adaptability to their intended uses. Brady warrants to the buyers that its products are free from defects in material and workmanship, but limits its obligation under this warranty to replacement of the product shown to Brady's satisfaction to have been defective at the time Brady sold it. This warranty does not extend to any persons obtaining the product from the buyers. This warranty is in lieu of any other warranty, express or implied, including, but not limited to, any implied warranty of merchantability or fitness for a particular purpose, and of any other obligations or liability on Brady's part. Under no circumstances will Brady be liable for any loss, damage, expense, or consequential damages of any kind arising in connection with the use, or inability to use, Brady's products. Copyright 2016 Brady Worldwide, Inc. | All Rights Reserved Material may not be reproduced or distributed in any form without written permission. Brady North America | 6555 W. Good Hope Rd | Milwaukee, WI 53223 | USA | Tel: 414­358­6600 | Fax: 800­292­2289
B33-5-483 价格&库存
很抱歉,暂时无法提供与“B33-5-483”相匹配的价格&库存,您可以联系我们找货
B33-5-483
