B33-53-7425
B33-53-7425
    BRADY
    BRADY - B33-53-7425 - LABEL, POLYPROPYLENE, WHITE, 12.7X50.8MM
B33-53-7425 数据手册
Brady B-7425 Workhorse® Series Thermal Transfer Labels As part of Brady’s Workhorse Label Series, the B-7425 thermal transfer labels are engineered to withstand the harshest environments across a wide variety of laboratory applications. These labels are constructed with durable polypropylene material to provide a tough and economical solution for improved identification and workflow tracking in the lab. They’re ideal for a broad range of processes and applications, including samples, inventory, general tracking, and identification of vials, tubes, racks, flasks, bags and other sample containers. Key features: OO OO OO OO OO OO OO OO OO OO OO Economical solution for vials and tubes from 0.5ml to 50ml Use on tubes, vials, boxes, racks, slides, microplates, flasks, dishes, bags or other general needs Apply to dry room temperature samples with no overlap needed Adhere to stainless steel, glass and polypropylene Withstand temperature ranges from -196°C to 121°C (-320°F to 248°F) Use in LN2, freezers, autoclave, and hot water baths. Chemical resistance to ethanol, DMSO, IPS, short term xylene, 10% formalin, 50% acetic acid and toluene Prints best with R6400 black ribbon (can also use R4300 or R6200 black ribbon) Stock sizes available for Brady portable and benchtop thermal transfer printers, as well as 1" and 3” core rolls for other industry printers Custom label sizes and print automation options available -AC indicates steam sterilization with a color changing pre-printed header when autoclaved at 250.7º F (121.5º C) for 10 minutes For more information, call a Brady Lab Specialist at 1-800-356-9951, contact your lab distributor or visit BradyID.com/lab Diagram Catalog # Material Color Label Width Inch (mm) Label Height Inch (mm) Label Area C Inch (mm) Labels Per Row Labels Per Pkg Rec. Ribbon B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425-AC B-7425 B-7425 B-7425 B-7425 B-7425-AC White White White White White White White White White White White White White White White White White 0.825 (21.0) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.300 (33.0) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 0.250 (6.4) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 0.600 (15.2) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 1.750 (44.5) 0.250 (6.4) 0.500 (12.7) 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) dia. 0.440 (11.1) dia. - 1 2 1 1 1 2 1 1 2 1 1 1 1 1 1 1 1 2000 2000 2000 sets 2000 2000 sets 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 IP-R4302, R4302 IP-R4302, R4302 IP-R4302, R4302 IP-R4302, R4302 IP-R4302, R4302 IP-R4302, R4302 IP-R4302, R4302 IP-R4302, R4302 IP-R4307, R4307 IP-R4302, R4302 IP-R4302, R4302 R4300 IP-R4302, R4302 IP-R4302, R4302 IP-R4302, R4302 IP-R4302, R4302 R4300 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 White White White White White White White White White White White White White White White 0.825 (21.0) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.300 (33.0) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 0.250 (6.4) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 0.600 (15.2) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 1.750 (44.5) 0.250 (6.4) 0.500 (12.7) 1.000 (25.4) 0.375 (9.5) dia. 0.440 (11.1) dia. - 1 2 1 1 1 2 1 1 2 1 1 1 1 1 1 2000 2000 2000 sets 2000 2000 sets 2000 2000 2000 2000 2000 2000 2000 2000 2000 2000 R4313 R4313 R4313 R4313 R4313 R4313 R4313 R4313 R4313 R4313 R4313 R4313 R4313 R4313 R4313 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425 B-7425-AC B-7425 B-7425 B-7425 B-7425 B-7425-AC White White White White White White White White White White White White White White White White White 0.825 (21.0) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.300 (33.0) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 2.000 (50.8) 0.250 (6.4) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 0.600 (15.2) 0.500 (12.7) 0.750 (19.1) 1.000 (25.4) 1.000 (25.4) 1.750 (44.5) 0.250 (6.4) 0.500 (12.7) 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) dia. 0.440 (11.1) dia. - 1 2 1 1 1 2 1 1 2 1 1 1 1 1 1 1 1 1500 2000 1500 2000 1500 2000 1500 1500 1500 1500 1250 1250 900 2000 2000 1500 1500 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 B30-R4300 BK on WT BK on WT BK on WT 0.375 (9.5) 0.500 (12.7) 0.750 (19.1) 21 ft (6.4 m) 21 ft (6.4 m) 21 ft (6.4 m) - IP Printer, PR+ Printers Fig. 29 Fig. 29 Fig. 24 Fig. 29 Fig. 24 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29a Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29a THT-257-7425-2 THT-152-7425-2 THT-249-7425-2 THT-59-7425-2 THT-251-7425-2 THT-88-7425-2 THT-179-7425-2 THT-256-7425-2 THT-37-7425-2 THT-136-7425-2 THT-235-7425-2 THT-235-7425-2-AC THT-258-7425-2 THT-151-7425-2 THT-53-7425-2 THT-137-7425-2 THT-137-7425-2-AC BBP12 Printer Fig. 29 Fig. 29 Fig. 24 Fig. 29 Fig. 24 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 THT-257-7425-2-SC THT-152-7425-2-SC THT-249-7425-2-SC THT-59-7425-2-SC THT-251-7425-2-SC THT-88-7425-2-SC THT-179-7425-2-SC THT-256-7425-2-SC THT-37-7425-2-SC THT-136-7425-2-SC THT-235-7425-2-SC THT-258-7425-2-SC THT-151-7425-2-SC THT-53-7425-2-SC THT-137-7425-2-SC A B C Figure 24 A = Label Width B = Label Height C = Label Diameter A B Figure B29 = Label Height A = Label Width A B = Label Height Figure B29a A = Label Width A BBP33 Printer Fig. 29 Fig. 29 Fig. 24 Fig. 29 Fig. 24 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29a Fig. 29 Fig. 29 Fig. 29 Fig. 29 Fig. 29a B33-257-7425 B33-152-7425 B33-249-7425 B33-59-7425 B33-251-7425 B33-88-7425 B33-179-7425 B33-256-7425 B33-37-7425 B33-136-7425 B33-235-7425 B33-235-7425-AC B33-258-7425 B33-151-7425 B33-53-7425 B33-137-7425 B33-137-7425-AC B Figure 33 A = Label Width B = Label Height BMP21-PLUS, BMP21-LAB Printers Fig. 33 Fig. 33 Fig. 33 M21-375-7425 M21-500-7425 M21-750-7425 B-7425 B-7425 B-7425 1 roll (cont.) 1 roll (cont.) 1 roll (cont.) For more information, call a Brady Lab Specialist at 1-800-356-9951, contact your lab distributor or visit BradyID.com - USA Customer Service: 1-888-272-3946 Inside Sales: 1-888-311-0775 BradyID.com Canada Customer Service: 1-800-263-6179 BradyCanada.ca Mexico Customer Service: 1-800-262-7777 Inside Sales: 1-800-262-7777 ext 177 BradyLatinAmerica.com © 2017 Brady Worldwide Inc. ALL RIGHTS RESERVED
B33-53-7425 价格&库存
很抱歉,暂时无法提供与“B33-53-7425”相匹配的价格&库存,您可以联系我们找货
B33-53-7425
    • 1+1823.448731+235.37121
