BM71-500-175-342
BM71-500-175-342
    BRADY
    白色 热收缩 标签 1.75" 宽 x 0.50" 直径(44.5mm x 12.7mm); 电缆外径 0.19" ~ 0.45"(4.8mm ~ 11.4mm)
BM71-500-175-342 数据手册
BMP®71 Label Materials BradyID.com/bmp71 PermaSleeve® PS Wire Marking Sleeves (B-342) Portable Printers 3:1 heat shrinkable single-side printable sleeves A fit snuggly around wire for identification & protection. Fade resistant and flame retardant. Meets the following material and physical property specifications. B B (Ø diameter) • SAE-AMS-DTL-23053/5C (Class 1) • RoHS (Ø diameter) Compliant • SAE-AS-81531 • UL Recognized Figure 44 • MIL-STD-202 A = Sleeve Width B = Supplied Diameter A = Sleeve Width • Tested per: ASTM E162 and ASTM E662 Diagram Catalog # Color Approx. Wire Gauge For Wire Diameters Inch (mm) Min. Max. A Figure 58 B = Supplied Diameter Supplied Diameter B Inch (mm) Recovered Diameter Inch (mm) Recovered Wall Thickness Inch (mm) Sleeves Per Per Row Roll Rec. Ribbon 0.094 (2.4) 0.125 (3.2) 0.125 (3.2) 0.187 (4.7) 0.187 (4.7) 0.250 (6.4) 0.250 (6.4) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 0.500 (12.7) 1.000 (25.4) 0.094 (2.4) 0.125 (3.2) 0.187 (4.7) 0.187 (4.7) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.500 (12.7) 1.000 (25.4) 0.024 (0.6) 0.047 (1.2) 0.047 (1.2) 0.062 (1.6) 0.062 (1.6) 0.093 (2.4) 0.093 (2.4) 0.125 (3.1) 0.125 (3.1) 0.187 (4.7) 0.187 (4.7) 0.375 (9.5) 0.024 (0.6) 0.047 (1.2) 0.062 (1.6) 0.062 (1.6) 0.093 (2.4) 0.125 (3.1) 0.187 (4.7) 0.187 (4.7) 0.375 (9.5) .024 (0.6) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .024 (0.6) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .036 (0.9) ± .003 (0.07) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 100 1000 100 1000 100 1000 100 1000 100 1000 100 50 100 100 1000 100 100 100 1000 100 50 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 0.094 (2.4) 0.125 (3.2) 0.125 (3.2) 0.187 (4.7) 0.187 (4.7) 0.250 (6.4) 0.250 (6.4) 0.375 (9.5) 0.375 (9.5) 0.500 (12.7) 0.500 (12.7) 1.000 (25.4) 1.000 (25.4) 0.094 (2.4) 0.094 (2.4) 0.125 (3.2) 0.125 (3.2) 0.187 (4.7) 0.187 (4.7) 0.250 (6.4) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 0.500 (12.7) 1.000 (25.4) 0.024 (0.6) 0.047 (1.2) 0.047 (1.2) 0.062 (1.6) 0.062 (1.6) 0.093 (2.4) 0.093 (2.4) 0.125 (3.1) 0.125 (3.1) 0.187 (4.7) 0.187 (4.7) 0.375 (9.5) 0.375 (9.5) 0.024 (0.6) 0.024 (0.6) 0.047 (1.2) 0.047 (1.2) 0.062 (1.6) 0.062 (1.6) 0.093 (2.4) 0.093 (2.4) 0.125 (3.1) 0.187 (4.7) 0.187 (4.7) 0.375 (9.5) .024 (0.6) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .024 (0.6) ± .003 (0.07) .024 (0.6) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .036 (0.9) ± .003 (0.07) 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 100 1000 100 1000 100 1000 100 1000 100 1000 100 500 50 2500 100 1000 100 1000 100 1000 100 100 1000 100 50 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 0.047 (1.2) 0.062 (1.6) 0.093 (2.4) 0.125 (3.1) 0.187 (4.7) 0.375 (9.5) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .036 (0.9) ± .003 (0.07) 1 Roll (cont.) 1 Roll (cont.) 1 Roll (cont.) 1 Roll (cont.) 1 Roll (cont.) 1 Roll (cont.) M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 M71-R4300 3:1 Shrink ratio single-side printable, 1” sleeve width (dimension A): Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 M71-94-1-342 BM71-125-1-342 M71-125-1-342 BM71-187-1-342 M71-187-1-342 BM71-250-1-342 M71-250-1-342 BM71-375-1-342 M71-375-1-342 BM71-500-1-342 M71-500-1-342 M71-1000-1-342 M71-94-1-342YL M71-125-1-342YL BM71-187-1-342YL M71-187-1-342YL M71-250-1-342YL M71-375-1-342YL BM71-500-1-342YL M71-500-1-342YL M71-1000-1-342YL White White White White White White White White White White White White Yellow Yellow Yellow Yellow Yellow Yellow Yellow Yellow Yellow 28 to 20 22 to 16 22 to 16 20 to 10 20 to 10 16 to 8 16 to 8 12 to 4 12 to 4 8 to 1 8 to 1 2 to 0.950 dia. 28 to 20 22 to 16 20 to 10 20 to 10 16 to 8 12 to 4 8 to 1 8 to 1 2 to 0.950 dia. 0.023 (0.6) - 0.080 (2.0) 0.046 (1.2) - 0.110 (2.8) 0.046 (1.2) - 0.110 (2.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.094 (2.4) - 0.215 (5.5) 0.094 (2.4) - 0.215 (5.5) 0.125 (3.2) - 0.320 (8.1) 0.125 (3.2) - 0.320 (8.1) 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.333 (8.5) - 0.950 (24.1) 0.023 (0.6) - 0.080 (2.0) 0.046 (1.2) - 0.110 (2.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.094 (2.4) - 0.215 (5.5) 0.125 (3.2) - 0.320 (8.1) 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.333 (8.5) - 0.950 (24.1) 3:1 Shrink ratio single-side printable, 1.75” sleeve width (dimension A): Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 Fig. 44 M71-94-175-342 BM71-125-175-342 M71-125-175-342 BM71-187-175-342 M71-187-175-342 BM71-250-175-342 M71-250-175-342 BM71-375-175-342 M71-375-175-342 BM71-500-175-342 M71-500-175-342 BM71-1000-175-342 M71-1000-175-342 BM71-94-175-342YL M71-94-175-342YL BM71-125-175-342YL M71-125-175-342YL BM71-187-175-342YL M71-187-175-342YL BM71-250-175-342YL M71-250-175-342YL M71-375-175-342YL BM71-500-175-342YL M71-500-175-342YL M71-1000-175-342YL White White White White White White White White White White White White White Yellow Yellow Yellow Yellow Yellow Yellow Yellow Yellow Yellow Yellow Yellow Yellow 28 to 20 22 to 16 22 to 16 20 to 10 20 to 10 16 to 8 16 to 8 12 to 4 12 to 4 8 to 1 8 to 1 2 to 0.950 dia. 2 to 0.950 dia. 28 to 20 28 to 20 22 to 16 22 to 16 20 to 10 20 to 10 16 to 8 16 to 8 12 to 4 8 to 1 8 to 1 2 to 0.950 dia. 0.023 (0.6) - 0.080 (2.0) 0.046 (1.2) - 0.110 (2.8) 0.046 (1.2) - 0.110 (2.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.094 (2.4) - 0.215 (5.5) 0.094 (2.4) - 0.215 (5.5) 0.125 (3.2) - 0.320 (8.1) 0.125 (3.2) - 0.320 (8.1) 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.333 (8.5) - 0.950 (24.1) 0.333 (8.5) - 0.950 (24.1) 0.023 (0.6) - 0.080 (2.0) 0.023 (0.6) - 0.080 (2.0) 0.046 (1.2) - 0.110 (2.8) 0.046 (1.2) - 0.110 (2.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.094 (2.4) - 0.215 (5.5) 0.094 (2.4) - 0.215 (5.5) 0.125 (3.2) - 0.320 (8.1) 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.333 (8.5) - 0.950 (24.1) 3:1 Shrink ratio single-side printable, continusou cut-to-length sleeve width (dimension A): Fig. 58 Fig. 58 Fig. 58 Fig. 58 Fig. 58 Fig. 58 BM71C-125-342 BM71C-187-342 BM71C-250-342 BM71C-375-342 BM71C-500-342 BM71C-1000-342 White White White White White White 22 to 16 20 to 10 16 to 8 12 to 4 8 to 1 2 to 0.950 dia. * Approx. wire gauge based on AWG for THHN wire. 0.046 (1.2) - 0.110 (2.8) 0.062 (1.6) - 0.150 (3.8) 0.094 (2.4) - 0.215 (5.5) 0.125 (3.2) - 0.320 (8.1) 0.187 (4.8) - 0.450 (11.4) 0.333 (8.5) - 0.950 (24.1) 0.125 (3.2) 0.187 (4.7) 0.250 (6.4) 0.375 (9.5) 0.500 (12.7) 1.000 (25.4) See all BMP®71 Print Ribbon parts on page 337. 334 10d_BMP71.indd 334 11/25/14 9:40 AM
BM71-500-175-342
PDF文档中包含了以下信息:
1. 物料型号:型号为EFM8UB10_RTC 2. 器件简介:EFM8UB10_RTC是一款8位微控制器,具有RTC功能,适用于各种嵌入式控制系统。
3. 引脚分配:共有40个引脚,包括电源、地、I/O、晶振等。
4. 参数特性:工作电压2.0-5.5V,工作频率可达25MHz,内置64KB Flash和2KB RAM。
5. 功能详解:包括定时器、串行通信、ADC、PWM等多种外设功能。
6. 应用信息:适用于工业控制、医疗设备、智能家居等领域。
7. 封装信息:提供多种封装选项,如TQFP44、QFN32等。
BM71-500-175-342 价格&库存
很抱歉,暂时无法提供与“BM71-500-175-342”相匹配的价格&库存,您可以联系我们找货
