BS08A-RD
BS08A-RD
    BRADY
    BRADY - BS08A-RD - PRINZING BALL VALVE LOCKOUT, LARGE, RED
BS08A-RD 数据手册
Valve Lockouts Plug Valve Lockout • Ideal for difficult-to-secure plug valves in compliance with OSHA standards • Four sizes to fit most 1” to 8” diameter manually-actuated plug valves • Durable and tamper-resistant • Service temps from -25°F to 200°F • Compact in size and easy to use • Unique knockout center fits OS&Y or “rising stem” valves • Versatile lockout adjusts to fit 1” to 6-1/2” valve handles, replacing 3 conventional gate valve lockouts • Made of rugged injection-molded polypropylene • Constructed of rugged injectionmolded polypropylene • Service temps from –25°F to 200°F • Accepts shackles up to 3/8” in dia. • Service temps from -13°F to 194°F • Supplied with English, Spanish and French danger labels • Supplied with English, Spanish and French danger labels Catalog # Description Catalog # Description 113231 113232 113233 113234 64057 Lockout for up to 7⁄8” Stem Dia. Lockout for 15⁄16” to1-3⁄8” Stem Dia. Lockout for 1-3⁄4” to 2-1⁄8” Stem Dia. Lockout for 2-3⁄16” to 2-1⁄2” Stem Dia. Gate Valve Lockouts Adjustable Gate Valve Lockout Lockout Tagout BradyID.com/lockouttagout Adjustable Gate Valve Lockout Fits Valve Handles Dia. Red Yellow Green Blue 1” to 2-1⁄2” 2-1⁄2” to 5” 5” to 6-1⁄2” 6-1⁄2” to 10” 10” to 13” 65560 65561 65562 65563 65564 65590 65591 65592 65593 65594 65595 65596 65597 65598 65599 65585 65586 65587 65588 65589 NEW! • Made from ultra-tuff polypropylene Standard Ball Valve Lockout Perma-Mount™ Ball Valve Lockout • Easy to use, single-piece design locks • Small size locks out pipes 1/2” to 2-1/2” in diameter • Two sizes fit most valves up to 3” • Retrofit devices stay permanently in place at the point of need • Small size can also lock valves OPEN on pipes from 1/2” to 1-1/4”in diameter • 65666 is made of super-tough nylon (service temp -40° to 248° F) • One-time installation is easy to complete in just a few minutes • Large size locks out pipes 2” to 8” in diameter • 65692, 65669 and 65693 are made of powder-coated steel • Available in 2 sizes to fit a full range of 0.5" to 4" diameter ball valves Catalog # Size Color BS07A-RD BS08A-RD BS07A-BU BS08A-BU BS07A-GN BS08A-GN BS07A-YW BS08A-YW Small Large Small Large Small Large Small Large Red Red Blue Blue Green Green Yellow Yellow Max Max Max Valve Size Catalog # Shackle Handle Handle / Pipe Dia. Dia. Width Thickness Prinzing Ball Valve Lockout quarter-turn ball valves in OFF position 65666 65692 65669 65693 9⁄32” 3⁄8” 9⁄32” 3⁄8” 1⁄4” to 1” 1⁄4” to 1” 1-1⁄4” to 3” 1-1⁄4” to 3” 1-888-272-3946 15_LOTO_Padlocks_Hasps.indd 477 1-1⁄2” 1-1⁄2” 2-1⁄10” 1-9⁄10” 3⁄4” 3⁄4” 11⁄4” 11⁄4” BradyID.com/s34 Catalog # Size 121540 121541 Small Perma-Mount Ball Valve Lockout Large Perma-Mount Ball Valve Lockout 477 11/17/14 3:51 PM
BS08A-RD
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光隔离型放大器,具有高输入阻抗和低输出阻抗,适用于长线驱动和匹配负载。
3. 引脚分配:EL817有8个引脚,其中1脚为输入,2脚为输出,3脚为Vcc,4脚为GND,5-8脚为光隔离部分。
4. 参数特性:工作电压范围为3.6V-15V,输入电流小于1mA,输出电流可达150mA。
5. 功能详解:EL817内部包含一个光敏三极管和一个达林顿晶体管,实现电-光-电转换和信号放大。
6. 应用信息:适用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用DIP-8封装。
BS08A-RD 价格&库存
很抱歉,暂时无法提供与“BS08A-RD”相匹配的价格&库存,您可以联系我们找货
