3PS-375-2-WT
3PS-375-2-WT
    BRADY
    白色 热收缩 标签 2.00" 宽 x 0.38" 直径(50.8mm x 9.5mm); 电缆外径 0.13" ~ 0.32"(3.2mm ~ 8.1mm)
3PS-375-2-WT 数据手册
PermaSleeve® Wire Marking Sleeves BradyID.com B-342 PermaSleeve® Double-Sided Polyolefin Wire Marking Sleeves: Catalog # 3PS-094-2-WT 3PS-094-2-WT-** 3PS-094-2-WT-S 3PS-094-2-WT-S-** Color White White White White Sleeves Per Roll 2,500 2,500 500 500 Approx. Wire Gauge 28 to 20 28 to 20 28 to 20 28 to 20 Range of Wire Diameter Inch (mm) Min. Max. 0.023 (0.6) - 0.080 (2.0) 0.023 (0.6) - 0.080 (2.0) 0.023 (0.6) - 0.080 (2.0) 0.023 (0.6) - 0.080 (2.0) Supplied Diameter Inch (mm) 0.094 (2.4) 0.094 (2.4) 0.094 (2.4) 0.094 (2.4) Recovered Diameter Inch (mm) 0.024 (0.6) 0.024 (0.6) 0.024 (0.6) 0.024 (0.6) Recovered Wall Thickness Inch (mm) .024 (0.6) ± .003 (0.07) .024 (0.6) ± .003 (0.07) .024 (0.6) ± .003 (0.07) .024 (0.6) ± .003 (0.07) Sleeve Width Inch (mm) 2.000 (50.8) -2.000 (50.8) -- Rec. Printer PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP Rec. Ribbon R4300/ R6602 R4300/ R6602 R4300/ R6602 R4300/ R6602 3PS-125-2-WT 3PS-125-2-WT-** 3PS-125-2-WT-S 3PS-125-2-WT-S-** White White White White 2,500 5,000 500 500 22 to 16 22 to 16 22 to 16 22 to 16 0.046 (1.2) - 0.110 (2.8) 0.046 (1.2) - 0.110 (2.8) 0.046 (1.2) - 0.110 (2.8) 0.046 (1.2) - 0.110 (2.8) 0.125 (3.2) 0.125 (3.2) 0.125 (3.2) 0.125 (3.2) 0.047 (1.2) 0.047 (1.2) 0.047 (1.2) 0.047 (1.2) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) 2.000 (50.8) -2.000 (50.8) -- PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP R4300/ R6602 R4300/ R6602 R4300/ R6602 R4300/ R6602 3PS-187-2-WT 3PS-187-2-WT-** 3PS-187-2-WT-S 3PS-187-2-WT-S-** White White White White 2,500 2,500 500 500 20 to 10 20 to 10 20 to 10 20 to 10 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.062 (1.6) - 0.150 (3.8) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.062 (1.6) 0.062 (1.6) 0.062 (1.6) 0.062 (1.6) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) .020 (0.5) ± .003 (0.07) 2.000 (50.8) -2.000 (50.8) -- PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP R4300/ R6602 R4300/ R6602 R4300/ R6602 R4300/ R6602 3PS-250-2-WT 3PS-250-2-WT-** 3PS-250-2-WT-S 3PS-250-2-WT-S-** White White White White 2,500 5,000 500 1,000 16 to 8 16 to 8 16 to 8 16 to 8 0.094 (2.4) - 0.215 (5.5) 0.094 (2.4) - 0.215 (5.5) 0.094 (2.4) - 0.215 (5.5) 0.094 (2.4) - 0.215 (5.5) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.093 (2.4) 0.093 (2.4) 0.093 (2.4) 0.093 (2.4) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) 2.000 (50.8) -2.000 (50.8) -- PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP R4300/ R6602 R4300/ R6602 R4300/ R6602 R4300/ R6602 3PS-375-2-WT 3PS-375-2-WT-** 3PS-375-2-WT-S 3PS-375-2-WT-S-** White White White White 1,000 2,000 250 250 12 to 4 12 to 4 12 to 4 12 to 4 0.125 (3.2) - 0.320 (8.13) 0.125 (3.2) - 0.320 (8.13) 0.125 (3.2) - 0.320 (8.13) 0.125 (3.2) - 0.320 (8.13) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.125 (3.1) 0.125 (3.1) 0.125 (3.1) 0.125 (3.1) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) 2.000 (50.8) -2.000 (50.8) -- PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP R4300/ R6602 R4300/ R6602 R4300/ R6602 R4300/ R6602 3PS-500-2-WT 3PS-500-2-WT-** 3PS-500-2-WT-S 3PS-500-2-WT-S-** White White White White 500 500 250 250 8 to 1 8 to 1 8 to 1 8 to 1 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.187 (4.8) - 0.450 (11.4) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) 0.187 (4.7) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) 2.000 (50.8) -2.000 (50.8) -- PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP R4300/ R6602 R4300/ R6602 R4300/ R6602 R4300/ R6602 3PS-750-2-WT 3PS-750-2-WT-** 3PS-750-2-WT-S 3PS-750-2-WT-S-** White White White White 250 250 100 100 6 to 4/0 6 to 4/0 6 to 4/0 6 to 4/0 0.250 (6.6) - 0.700 (17.8) 0.250 (6.6) - 0.700 (17.8) 0.250 (6.6) - 0.700 (17.8) 0.250 (6.6) - 0.700 (17.8) 0.750 (19.0) 0.750 (19.0) 0.750 (19.0) 0.750 (19.0) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) 0.250 (6.4) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) .025 (0.6) ± .003 (0.07) 2.000 (50.8) -2.000 (50.8) -- PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP R4300/ R6602 R4300/ R6602 R4300/ R6602 R4300/ R6602 3PS-1000-2-WT 3PS-1000-2-WT-** 3PS-1000-2-WT-S 3PS-1000-2-WT-S-** White White White White 250 250 100 100 2 to 0.950 dia 2 to 0.950 dia. 2 to 0.950 dia. 2 to 0.950 dia. 0.333 (8.5) - 0.950 (24.1) 0.333 (8.5) - 0.950 (24.1) 0.333 (8.5) - 0.950 (24.1) 0.333 (8.5) - 0.950 (24.1) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 1.000 (25.4) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) 0.375 (9.5) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) 2.000 (50.8) -2.000 (50.8) -- PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP R4300/ R6602 R4300/ R6602 R4300/ R6602 R4300/ R6602 3PS-1500-2-WT 3PS-1500-2-WT-** 3PS-1500-2-WT-S 3PS-1500-2-WT-S-** White White White White 250 250 100 100 N/A N/A N/A N/A 0.500 (12.7) - 1.400 (35.6) 0.500 (12.7) - 1.400 (35.6) 0.500 (12.7) - 1.400 (35.6) 0.500 (12.7) - 1.400 (35.6) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 1.500 (38.1) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) 0.500 (12.7) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) .036 (0.9) ± .003 (0.07) 2.000 (50.8) -2.000 (50.8) -- PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP PR Plus, BBP72, IP R4300/ R6602 R4300/ R6602 R4300/ R6602 R4300/ R6602 *Choosing Your PermaSleeve Color ** Choosing Your PermaSleeve Pieces (optional): While white is a standard color, additional colored sleeves are available as custom order as well. Simply replace “WT” with the abbreviation of the desired color to order. Example: PS-094-150-WT-S becomes PS-094-150-RD-S WT = White BR = Brown GR = Green GY = Gray YL = Yellow BK = Black OR = Orange PK = Pink RD = Red BL = Blue IP Series, PR Plus & BBP72 Print Ribbons on page 134 Full Material Properties on page 227. While 1 or 2 markers per sleeve is standard, you may also choose to have each sleeve slit multiple times to produce multiple pieces. Simply replace the double asterisks (**) in the catalog number to fill in your desired pieces per marker. Example: PS-187-150-WT-S-** becomes PS-187-150-WT-S-4 This “4” means that this 2.000” sleeve is slit into four 0.500” pieces. Available Colors: (Contact Brady Customer Service for availability) WT = White BK = Black BL = Blue PermaSleeve Wire Markers Double-Sided Printable, 2” Sleeve Width THT Label Materials Use the table below to browse all available double-sided printing, 2” width B-342 PermaSleeve® 3PS Polyolefin Wire Marking Sleeves or build your own catalog number on page 184. VT = Violet YL = Yellow BR = Brown Standard Options: 1 or 2 markers per sleeve GR = Green 1-888-272-3946 GY = Gray BradyID.com Other Available Slit Options: 3 or 4 markers per sleeve (Contact Brady Customer Service for availability) OR = Orange PK = Pink RD = Red VT = Violet 187
3PS-375-2-WT 价格&库存
很抱歉,暂时无法提供与“3PS-375-2-WT”相匹配的价格&库存,您可以联系我们找货
3PS-375-2-WT
  • 1+15557.653481+2006.97709
