GATE VALVE LOCKOUTS GVLO 5-6.5 RED
    BRADY
    BRADY - GATE VALVE LOCKOUTS GVLO 5-6.5 RED - GATE VALVE LOCKOUT, RED, PP
GATE VALVE LOCKOUTS GVLO 5-6.5 RED 数据手册
Technical Data Sheet Brady Gate Valve Lockouts TDS No. LOTO-​7 Effective Date: 10/16/2017 Description: Design ● ● Made of rugged injection-​molded polypropylene Includes a unique knock​-out center that accommodates OS&Y or "rising stem" valves These gate valves come are available in 5 sizes, to effectively cover valve hand wheels of 1" to 13" (25 to 330mm) in diameter, and are available in four colors Accepts locks with shackles up to 3/8" (9,5mm) in diameter, and are supplied with danger labels in English, Spanish and French ● ● Material ● ● ● ● Housing: Polypropylene Rivet, Washers: Steel Housing Color: ○ Red (PMS 1805C) ○ Blue (PMS 300) ○ Yellow (PMS 7460) ○ Green (PMS 340) UL Rating: UL 94 – HB (Plastic Components Only) Temperature Range Polypropylene: -​40° to 150°C (-​40° to 300°F) Chemical Resistance All approved chemicals listed are based on the manufacturer's specified chemical resistance chart for plastic material only. All other materials in the device are made of steel. Dimensions A B C 1​2.5” (25-​ 64mm) 4.72” 2.5 ​5” (64​127mm) 7.28” 5 ​6.5” (127​165mm) 8.82” 6.5​10” (165​254mm) 12.53” 10​13” 254​330mm) 15.95” (120.1mm) (184.8mm) (224.1mm) (318.3mm) (405.1mm) .38” .38” .38” .38” .38” (9.7mm) 1.41” (9.7mm) 2.0” (35.9mm) (50.6mm) (9.7mm) 2.38” (9.7mm) 3.0” (9.7mm) 3.0” (60.4mm) (76.2mm) (76.2mm) Chemical °C Chemical Acetone 25 Petroleum Acetone 60 Lubricating oil: HD engine oils, hydraulic oils, transformer oils Lubrication oil: gear oil < 120 °C 25 < 120 Fuel, engine: M15 mixture (15% methanol) 70 Water (including seawater) 25 Methanol 25 Water (including seawater), chlorinated (
GATE VALVE LOCKOUTS GVLO 5-6.5 RED 价格&库存
很抱歉,暂时无法提供与“GATE VALVE LOCKOUTS GVLO 5-6.5 RED”相匹配的价格&库存,您可以联系我们找货
